Cut Through Extension Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 08:34 PM   #1
Rewards Points: 39
Cut through extension cord
Long story short, hedge trimmer cut through the extension cord. Power on that breaker stuttered enough to turn off the TV, but the breaker didn't actually trip. Should I be worried? The breaker is a standard 20A and the cord was literally cut in half. No, I wasn't doing the trimming. I was watching the TV.
Sliding Man is offline   Reply With Quote
Old 11-13-2011, 08:52 PM   #2
Rewards Points: 6,652
If there is a gfci outlet, then no the breaker would not have tripped, but the gfci would have.
Old 11-13-2011, 09:37 PM   #3
Rewards Points: 39
Just a plain outlet in the garage. In fact, there are no GFCIs anywhere in the garage.
Old 11-13-2011, 09:43 PM   #4
Really can not tell you, other than if the cut was made quick enough, so that it did not short the hot & neutral, the breaker would not have tripped also. Keep in mind, that there are times that garages are piggy backed off of another circuit, such as a bath, laundry, kitchen, basement, or even outside.
The Following User Says Thank You to gregzoll For This Useful Post:
Sliding Man (11-14-2011)
Old 11-13-2011, 09:53 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Turn the breaker in question completely off, then back on, just to be sure it's reset. Shouldn't be a problem. Is the TV still working?
Kyle
Old 11-14-2011, 03:32 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,514
If you have any concerns !
And you do !
Fit a gfci.
dmxtothemax is offline   Reply With Quote
Old 11-14-2011, 09:05 AM   #7
Rewards Points: 770
is it a federal pacific breaker
carmusic is offline   Reply With Quote
Old 11-14-2011, 09:49 AM   #8
GE breakers are notorious for this kind of action. I would replace the breaker in question.
Colomboj is offline   Reply With Quote
Old 11-14-2011, 05:21 PM   #9
Just because the breaker failed to trip when the ext cord was cut,
doesnt mean it is faulty.
So I would not replace it on solely on this response.
If the cut was quick and clean,
then the short might have been only very breif.
not enough to trip the breaker.
This would be considered normal response.
If you want a higher level of protection
then you should use GFCI's.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 11-14-2011, 06:39 PM   #10
It might be a Zinsco..
Master of Cold is offline   Reply With Quote
Old 11-14-2011, 09:56 PM   #11
Rewards Points: 39
It's a GE panel, but I can't tell what the breakers are. They have no name or stickers on them anywhere.
Connecting a battery backup to an extension cord (or vice versa); safe? kev77 Electrical 2 03-19-2011 01:02 PM
Is my extension cord OK? MT Stringer Electrical 4 10-20-2009 07:25 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
