Cut Pipe Or Move Meter Cable? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 08:36 PM   #16
Master Electrician
Rewards Points: 3,826
Perhaps the "idiot" used an existing hole for the new SE. That is something this "idiot" would have done.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
J. V. (01-24-2013)
Old 01-21-2013, 08:39 PM   #17
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yeah rather than boring another large hole in the home it's what I would have done too.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-21-2013, 08:52 PM   #18
I assume hiring an electrician to disconnect the cable and run it underneath the copper pipe would be rather expensive.
I'm greatful there is only one large hole bored into the side of my house.
Paintrunner is offline   Reply With Quote
Old 01-21-2013, 09:08 PM   #19
rrolleston's Avatar
Probably more expensive than the pipe. But you could always price out both ways. The only deal with the heating pipe you will want to make sure that the antifreeze solution is still strong after you remove the fluid and pressurize it again.
Old 01-21-2013, 09:14 PM   #20
rrolleston's Avatar
Looking at the pic again that pipe will be squeezing the wire against the wood all the time and since heating pipes expand and contract all the time it don't sound like a good idea. I would add some elbows and go over the wire to clear it and leave some room.
Old 01-22-2013, 07:34 AM   #21
Rewards Points: 6,652
Actually it would just be heated water, no antifreeze in a system that old.
Old 01-22-2013, 07:45 AM   #22
joed's Avatar
Rewards Points: 12,458
If the heating system is inside an always heated house there is no reason for anti freeze in it.
Old 01-22-2013, 09:34 AM   #23
At some point someone wrote "anti-freeze" on the pipes with marker, so I'm assuming they have anti-freeze in them.
Adding elbows and going over the wires sounds like a good plan. If working with Shark bites I can do it with my father in law.
If it involved moving the cable I'd have to hire someone.
Thanks guys!
Old 01-22-2013, 09:48 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Coastal South Carolina
Old 01-22-2013, 02:07 PM   #25
Originally Posted by rjniles View Post
damn that's awesome....that might be the route I go!
Thanks!
Old 01-22-2013, 11:52 PM   #26
" Euro " electrician
frenchelectrican's Avatar
That aluminum se cable I always find it to be really easy to bend. It's the URD cables and larger copper that I find are usually hard to bend. Most I ever get to deal with around here is 250 300.
What kind of puller do you use on a pull like that?
I used Greenlee Tugger 8Klbs class unit they work allright for most of the pull beside some very long vertical pull we used differnt puller for that purpose.
But for few very light pulls we have smaller unit that fit our purpose.
Merci,
Marc
Old 01-23-2013, 05:14 AM   #27
Lic Elect/Inspector/CPO
Originally Posted by joecaption View Post
PS All houses are wire 220 from the incoming power line, it gets split in the panel box to 110 on each side.
They may have upgraded for say a 60 to a 100 amps panel or more but did not "change" it to 220 V.
Believe it or not there some houses that still only have 110 volts services.
I have switched several from 110 to 220 in the past year.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
frenchelectrican (01-23-2013)
Old 01-23-2013, 10:53 PM   #28
For the past couple years I working in France and there is only just few left still on 127 volt network system and that about pretty much history beside the motel some of the fancyer one do have optional 120 volt circuit avaiable but not all locations will have that on hand.
Merci,
Marc
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
I need to test a cable for a kitchen range justplumducky Electrical 4 10-21-2012 11:23 PM
proximity of copper h2o pipe to MC cable amakarevic Electrical 5 10-26-2011 10:24 PM
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 07:55 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
