Cut Off Switch For Car Battery Blowing Fuses - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-24-2013, 08:28 PM   #31
If the solenoid was faulty would it still function and let power through as it's supposed to? Or would it just fail to power up the car regardless of circumstances?
IAmSupernova is offline   Reply With Quote
Old 05-24-2013, 08:30 PM   #32
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,392
CJM... I agree with you the whole way. To the best of my knowledge, that solinoid cicut (that trips the contacts) is independent of all other automotive draw.
Is there anything with DC that we are missing.????
MTN REMODEL LLC is offline   Reply With Quote
Old 05-24-2013, 08:36 PM   #33
Rewards Points: 254
Supernova it could be shorting to ground internally at times but still work. Mtn can't think of any other possibilities.
cjm94 is offline   Reply With Quote
Old 05-24-2013, 08:39 PM   #34
Okay then I will operate under the assumption it's faulty and get it replaced.. HOPEFULLY that's it.
Old 05-24-2013, 08:46 PM   #35
Rewards Points: 254
I would trace all the wires with your fingers one more time just to make sure there isn't a cut shorting out that you missed.
The Following User Says Thank You to cjm94 For This Useful Post:
MTN REMODEL LLC (05-24-2013)
Old 05-24-2013, 08:54 PM   #36
SuperNova . I would have to think if there is any relation here to your issue...which I at first thouhgt I think no relation....
but, (afetr afew beers thinking) you've got big wire, battery cable in essence , multi strand, hooking to/thru that solinoid.... which is difficult to attach to a terminal.... sure there is no short involved around that tough connection.
Old 05-24-2013, 08:55 PM   #37
Originally Posted by cjm94 View Post
i would trace all the wires with your fingers one more time just to make sure there isn't a cut shorting out that you missed.
yes yes
Old 05-24-2013, 08:56 PM   #38
I did and there's not. I guess a faulty solenoid kinda makes sense given the randomness of when the fuse goes. At least now it does.. I was just under the assumption if it was faulty it wouldn't function at all.
Old 05-24-2013, 08:59 PM   #39
Rewards Points: 3,256
A safety recommendation. It would be a good idea to move your fuse close to your battery on the wire feeding the switch. That way, all of your wiring going to and from your switch will be protected and not burn your car up if shorted.
zappa is offline   Reply With Quote
Old 05-24-2013, 08:59 PM   #40
Hey CJM... I'm much better with residentiakl and Ac..... but is there any odd-ball chance that Super's issue could be involved with his supply (ie battery)
Last edited by MTN REMODEL LLC; 05-24-2013 at 09:05 PM. Reason: wrong name reference
Old 05-24-2013, 09:02 PM   #41
I'm also wondering where that fuse goes in your last pic close to the battery?
Old 05-24-2013, 09:09 PM   #42
Rewards Points: 254
As long as the connections are good I wouldn't think so. A shorted battery internal would drain itself but wouldn't blow fuses. It looks like a fairly new battery.
Old 05-24-2013, 09:12 PM   #43
My assumption was the fuse holder was in the second pic, right North at 11 oclock from where A and B terminate at the toggle.
Zappa... I was a little confused, and could not really get my orientation to the pics, but coupled with Supers drawing, I thought/assumed it was correctly wired.
Old 05-24-2013, 09:16 PM   #44
Noted and will do. The fuse is connected to wire B, like right by the switch. Not close to the battery. The battery has also been switched out multiple times becuase the car kept eating them. We went through like 3 or 4 of them, completely drained over night and couldn't figure out the problem. This one has been disconnected and waiting for all of this before being used. So yeah, it's pretty much brand new.
Old 05-24-2013, 09:17 PM   #45
Hey SuperNova.... Are ya driving, kinda my ssumption, an old muscle nova.
Any chance you're driving a BMW 535 series. ?? Not kidding... I have some answers.
Peter
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Dimmer switch blowing out billybigrig Electrical 6 04-09-2013 12:34 AM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
