Cut Off Switch For Car Battery Blowing Fuses - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2013, 08:16 PM   #16
Rewards Points: 3,256
Originally Posted by IAmSupernova View Post
I have no idea how much it's supposed to draw. I'm just doing what I was told to do after several discussions with several people. I have tried to see what current is being produced, by hooking my multimeter up to the place where the fuse goes and flipping the switch, but my multimeter only handles DC volts up to 10 amps and I got an overload reading.. So no I don't have a way to to measure it.
You really need to find this information out before you can continue. You could ohm the coil but I would rather you find a spec sheet on the coil current.
zappa is offline   Reply With Quote
Old 05-24-2013, 08:18 PM   #17
Any chance that the switch is shorting out under the dash when that panel is pushed into place?
cootrp14 is offline   Reply With Quote
Old 05-24-2013, 08:30 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,362
Super... Incidentally, I'm not an automative technician... just sorta Saterday mechanic trying to help.
Did the solinoid indicate it's amp draw on the package. (Incidentally, I don't think that's the issue... I would think it's well below 10A@12V.)
I would make sure your mounting of that solinoid is making a good ground....use a file if necessary to ensure good solinoid to frame or engine connection/ground.
I don't think it causes your fuse blow at all, (which is just your relay draw causing the load), but under heavy load conditions at starting, I would have thought the max load on that solinoid would be 2 to 3 times 200A for its contacts.
Bottom line, your wiring looks fine to me... I don't have an answer.
Hopefully, some of the smarter guys will chime in... MPoul and Stick Jag... etc WTFAY?.
Best
Peter
Oh... Incidentally, understand your thoughts as to Dr Phil telling you to find/correct the automotive leak problem. I've got a Mom too.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-24-2013, 08:33 PM   #19
Rewards Points: 254
Originally Posted by danpik
If that solenoid draws 20 amps to actuate then you may need to go to a bigger wire and fuse.
How did you try to find the current draw on the system? Back in the day when I did this for a living I sed to connect a test light between the battery terminal and the cable. If there was a draw the light would light up. I then would pull one fuse at a time until the light went out. That would at least narrow it down to a few items to look at. Some newer cars this may not work on though
Yes that's the way we still do it. Just more fuses to pull. That looks like an automotive solenoid. Not all are rated for continuos duty. But none of them should take more than an amp or two to activate. I would be looking for a shorted wire maybe where it's pulled through the firewall. Some solenoids need to be grounded also.
cjm94 is offline   Reply With Quote
The Following User Says Thank You to cjm94 For This Useful Post:
MTN REMODEL LLC (05-24-2013)
Old 05-24-2013, 08:37 PM   #20
All solinoids need to be grounded
Old 05-24-2013, 08:39 PM   #21
This is also a possibility.
BTW, kind of a related question about your leakage problem. Does that fuse shown in your last pic near the battery go to an amplifier by any chance?
Old 05-24-2013, 08:42 PM   #22
Rewards Points: 254
You are right to clarify. I meant to say some are grounded through the case and some need a ground wire on auto solenoids.
Old 05-24-2013, 08:46 PM   #23
That's what I am thinking also. I can't see it drawing so much current. I followed the OP's link and the solenoid is supposed to be continous duty for like a golf cart.
The Following User Says Thank You to zappa For This Useful Post:
Old 05-24-2013, 08:49 PM   #24
Rewards Points: 254
Should work fine then if wired correctly. But for the amount and time he has invested he could have paid a good shop to diag his concern. It's not to hard for an experienced tech.
Old 05-24-2013, 09:04 PM   #25
Okay so I just went and used more battery cable to ground the solenoid to the negative battery cable (as suggested on another forum) because there was a 22 ohm (think that's what that symbol was for) resistance between the negative terminal and the case of the solenoid. I grounded it out so that there was a .5 resistance and went to test it. Flipped the switch a dozen times to make sure it was working, started it twice and all seemed fine. Then I went to get my wife and she went to flip the switch and it didn't power up. It blew a fuse again.. I'm going out again to check and see if it is the switch shorting out. We don't have an amplifier.
IAmSupernova is offline   Reply With Quote
Old 05-24-2013, 09:08 PM   #26
Rewards Points: 254
Are you sure you are not contacting any metal when you put that panel back in place causing a short?
Old 05-24-2013, 09:10 PM   #27
A solid ground is needed but it has nothing to do with your fuse blowing. Yeah, check for shorts everywhere.
Old 05-24-2013, 09:15 PM   #28
There's no short anywhere.. Not in my wiring anyways. I removed the switch from the panel and just let it dangle on the floor. Still blew the fuse. There's no where else for it to short out, none of the wires are damaged or exposed or making contact anywhere they're not supposed to.
Old 05-24-2013, 09:19 PM   #29
Super... Still have no answer.... but 22 ohm is not a ground.
Not to be personal, but maybe your wife is hot.
best
Peter
Old 05-24-2013, 09:19 PM   #30
Rewards Points: 254
If your positive of no shorts my guess would be a faulty solenoid then. I can't see any other reason for blowing the fuse.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Dimmer switch blowing out billybigrig Electrical 6 04-09-2013 01:34 AM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 06:31 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
