Cut Ground Wire, Okay To Reuse? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 08:32 PM   #1
Cut ground wire, okay to reuse?
Hey all -
I'm in the process of adding a kitchen peninsula and want to add an outlet on the wall above the counter.
I went up in the attic to scope things out, and lucky me - there's already a wire running from the nearby 20A outlet that terminates in the attic. I think there used to be a partition wall in the kitchen that this ran to. Anyway, it looks like someone intentionally dug the ground out from the middle of the run and snipped it!
As I really don't want to run a whole new wire to the existing outlet, is there any acceptable way to re-use this wire or repair it? Any drawbacks to simply installing a GFCI without the equipment ground?
rushty6 is offline   Reply With Quote
Old 04-23-2013, 09:18 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by rushty6 View Post
Hey all -
If they only cut the ground wire, then just cut the entire wire and box it out and re-splice all the conductors. Use two boxes if you cant reclaim any slack to remake the splice.
Old 04-23-2013, 09:32 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,898
Since the circuit is actually grounded, and was presumably required to be grounded when it was installed, you cannot legally use a GFCI instead of an equipment grounding conductor. You can just cut a section of cable out, install a J-box at each cut end, and run a short piece of new cable in between. It is odd for someone to have intentionally cut the grounding conductor. They may have done it for a reason (fault? used as a traveler? who knows...) so you should check to make sure it is properly connected at both ends and there isn't something dangerous and weird going on.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-23-2013, 09:34 PM   #4
Licensed electrician
Rewards Points: 1,258
You should also make sure it it part of the small appliance countertop circuit before extending it into the kitchen.
Old 04-23-2013, 10:04 PM   #5
The outlet it's coming from is a 20A in the kitchen, although near the floor and not countertop. This outlet is the only thing on that circuit and almost never used.. sound okay?
Old 04-23-2013, 10:08 PM   #6
Ha, too late.. whoever ripped out the partition wall just pulled the extra wire into the attic and let it sit there, no wire nuts, tape, nothing to cap the ends. And it was still hot
Old 04-23-2013, 10:28 PM   #7
A 20 amp circuit serving receptacles in the kitchen and/or dining room would be acceptable to run to the island.
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
voltage on ground wire - multiple ground problem? Thaiman Electrical 14 04-02-2011 12:49 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
