Cut-In Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 05:21 PM   #1
Cut-In box question
I live in an attached townhome and am in the process of adding an interior room to my home. The common wall is existing and is made up of 2 sheets of 5/8" drywall. I want to use "cut-in" boxes or for a lack of a better term a box with tabs that pull on the inside of the drywall to secure it rather than attaching it to the studs. Do they make a box that would work for 1 1/4" inches or more of drywall? Any other ideas to get a single gang box in the wall without having to attach it directly to a stud and cut the existing drywall?
Chris
solidworks400 is offline   Reply With Quote
Old 02-19-2012, 05:26 PM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
I have used some old work boxes (the ones you are talking about) in a house with plaster and lathe which can be pretty thick. What i did is took one of the screws that hold the tab out and took it to the screw isle and got a longer screw of the same size. That should work for you
danrb007 is offline   Reply With Quote
Old 02-19-2012, 05:37 PM   #3
Sparky
Rewards Points: 510
In my area, old work/cut in boxes are not allowed in a fire rated assembly, boxes must be 'attached to the framing members', not the drywall.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
Code05 (02-19-2012)
Old 02-19-2012, 06:22 PM   #4
Master Electrician
Rewards Points: 3,960
Excellent point.
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
Code05 (02-19-2012), rjniles (02-19-2012)
Old 02-19-2012, 06:34 PM   #5
Simple work around could be to use a cut in box and once attached toe nail two drywall screws into the stud. Problem solved. Would I be wrong in saying so? Also being not too familiar with the NEC, where would the codes for this sort of application be found?
Old 02-19-2012, 06:34 PM   #6
Code05's Avatar
Rewards Points: 1,104
I imagine in most areas, plus fire rated putty pads, no shared bays of boxes, and wire type can be factors.
In short, DIYers should leave fire rated separation walls alone IMO.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
brric (02-19-2012), plummen (02-19-2012)
Old 02-19-2012, 06:36 PM   #7
Code05's Avatar
NEC, IRC, IBC, IFC, NFPA 72, and UL Orange book.
Old 02-19-2012, 07:00 PM   #8
Code05's Avatar
Yes.
Old 02-19-2012, 08:05 PM   #9
In your opinion why should DIYers leave fire rated separation walls alone? In a pre-drywall walkthrough of my home, the wiring and wire type in that wall was no different than in any other part of the house. Also why would I be wrong in saying adding a toenailed screw to a cut-in box would work? The fact that I don't know is why I am asking these questions, please do not think that I am calling you incorrect.
Also, so that I can read up on it, where in the NEC would I find this info?
Old 02-19-2012, 08:37 PM   #10
Master Electrician
Nec 300.21
The Following User Says Thank You to brric For This Useful Post:
Code05 (02-20-2012)
Old 02-19-2012, 08:37 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Liability,youre now affecting yourself and your neighbor
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Code05 (02-20-2012)
Old 02-20-2012, 12:12 AM   #12
Rewards Points: 264
So if boxes need to be rigidly connected to a framing member in a fire wall, does anyone know why/how the plastic old work boxes got the UL 2-hour fire rating stamp?
a_lost_shadow is offline   Reply With Quote
Old 02-20-2012, 09:09 AM   #13
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Journeyman Plumber
Old 02-20-2012, 09:13 AM   #14
Doing it myself
Alan's Avatar
Is that an F rating or a T-rating?
Also just to throw this out there: What's the rating of the wall in question?
Journeyman Plumber
Old 02-20-2012, 11:10 AM   #15
Thadius856's Avatar
Rewards Points: 504
The old work Raco boxes I buy have the screw ends stamped so they can't be pulled out accidentally while in the wall. Be prepared to cut the screw if you want to remove it and this is the case.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
