Custom Wiring A Generator To A Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 10:57 AM   #1
Question
Custom wiring a generator to a transfer switch
Hi -
I have a Coleman generator - PowerBase Series, Model PM 0542000.01. It is 2250 Watts, 120 Volts, 18.75 Amps, single phase that I want to hook up to a Reliance 30216A transfer switch. The transfer switch has 6 switches and is rated for 120/240 volts 240 volts are achieved by using switch 3 and 4 tied together. I'm going to de-couple those and only use the circuits as 120 volts.
The transfer switch has 4 wires for input Green (ground), White (neutral), Red and Black.
The generator has 2 standard 3-prong outlets that you would normally plug an extension cord into.
My question is: I'm going to plug 2 extension cords into the two plugs on the generator, so how do I wire the outputs from the two plugs on the generator to power the transfer switch? I think it's like this:
A) Connect ground from plug 1 to ground from plug 2 then connect this to the Green (ground) wire on the transfer switch.
B) Connect neutral from plug 1 to neutral from plug 2 then connect this to the White (neutral) wire on the transfer switch.
C) Connect the Hot from plug 1 to the Black wire on the transfer switch.
D) Connect the Hot from plug 2 to the Red wire on the transfer switch.
Is that right? Does anyone see a problem with doing it this way?
Thanks in advance!!
- robojoe_fl
robojoe_fl is offline   Reply With Quote
Old 06-07-2011, 11:39 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
You do not have a 240 genset.
Yoou will only have 120 volts at the panel.
jbfan is online now   Reply With Quote
Old 06-07-2011, 05:57 PM   #3
Rewards Points: 1,442
You may have only one cord and plug for this transfer switch. Connect both the red and black hot lines of the transfer switch unit to the black wire of the power cord (hot prong of the 120 volt plug).
If the wiring in the transfer switch and also your power cord is 12 gauge or thicker, you may get a 20 amp plug for this power cord.
Old 06-07-2011, 09:01 PM   #4
Thanks for the input
Thanks for replying guys. Connecting both red and black in the transfer switch to the hot from a single extension cord seems to be the way to go...
Old 06-08-2011, 01:36 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Also you may want to put a warning sticker on the generator panel stated " no 240 volts " or " 120 volts only " one of the two will meet the requirement to forewarn someone else that you do not have 240 volts in there so in case someone try to hook up a 120/240 volt generator and use diffrent cord or other means and not have to cause a short circuit due you bridge one set.
Merci,
Marc
Tags
custom wire , generator , transfer switch
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 11:11 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Wiring two floodlights to a triple switch chrisjardine12 Electrical 20 01-23-2009 01:29 PM
