Custom Reptile Electrical-Thermostat How To Question... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 06:02 PM   #1
Question
Custom Reptile Electrical-Thermostat how to question...
Hello,
I have a pet snake and currently use a lamp dimmer to manually control my under the tank heater (heat pad) to about 88 degrees. Without it it reaches about 115-120 degrees.
I would like to somehow automate this using a digital thermostat and make it myself without really spending a whole lot for a actual thermostat designed by commercial sources in the reptile industry.
The old way was to use a light dimmer and cut the cord and insert between power and heating pad and we're good to go but now can do it via a lamp dimmer extention cord ($10 bucks at home depot).
I want to take it a step further and see if I can somehow rig/modify a $15 digital thermostat from homedepot. My understanding of room thermostats controlers sense the room temp and shuts off. In my case I want to bypass or extend that by putting the sensor directly on the heat source.
That way I can set the digital temp and it'll sense the heat at the probe end and then shut down.
Can it be done cheaply close to $15 as possible? How can it be done?
Thank you in advance.
David
Davidcyborg is offline   Reply With Quote
Old 01-13-2012, 06:21 PM   #2
Rewards Points: 1,580
Why not try something from a place like this:
http://www.drsfostersmith.com/reptil...s/c/6016/11148
Likely safer and will work.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
gregzoll (01-13-2012)
Tags
custom , electrical , reptile , thermostat
truck electrical question itin1200 Electrical 8 03-31-2011 01:58 PM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 09:43 AM
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 09:20 AM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
