-   -   Custom Reptile Electrical-Thermostat how to question... (http://www.diychatroom.com/f18/custom-reptile-electrical-thermostat-how-question-129850/)
Davidcyborg 01-13-2012 06:02 PM
Hello,
I have a pet snake and currently use a lamp dimmer to manually control my under the tank heater (heat pad) to about 88 degrees. Without it it reaches about 115-120 degrees.
I would like to somehow automate this using a digital thermostat and make it myself without really spending a whole lot for a actual thermostat designed by commercial sources in the reptile industry.
The old way was to use a light dimmer and cut the cord and insert between power and heating pad and we're good to go but now can do it via a lamp dimmer extention cord ($10 bucks at home depot).
I want to take it a step further and see if I can somehow rig/modify a $15 digital thermostat from homedepot. My understanding of room thermostats controlers sense the room temp and shuts off. In my case I want to bypass or extend that by putting the sensor directly on the heat source.
That way I can set the digital temp and it'll sense the heat at the probe end and then shut down.
Can it be done cheaply close to $15 as possible? How can it be done?
Thank you in advance.
David
bob22 01-13-2012 06:21 PM
Why not try something from a place like this:
http://www.drsfostersmith.com/reptil...s/c/6016/11148
Likely safer and will work.
