Old 05-09-2009, 06:07 AM   #1
Custom Power Supply: Help Please :|
I have built a 1amp 7.2volt power supply and i'm wondering if it will be able to charge a
7.2volt 1600mAh battery.
please help me.
Thanks In Advance.
tigerpushpop is offline   Reply With Quote
Old 05-09-2009, 06:52 AM   #2
My License Ain't 4 Sale..
please help me.
Thanks In Advance.
Well, yes and no. How are you regulating the voltage? How are you preventing the battery from overcharging? What type of battery is it?
You haven't provided enough information about your power supply circuit for us to help.
Old 05-09-2009, 07:01 AM   #3
I am trying to charge a 7.2v 1600mAh nickel medal hidride 5 cell battery pack and i'm using a variable switch which can take the power supply down to exactly 7.2volts. i have been told that the power supply produces 1 amp and the battery is only 1600mAh.
I'm not quite sure how to stop the battery from over charging, is there a little relay or something that will do it?
Old 05-09-2009, 08:39 AM   #4
A nickel metal hydride cell is pretty delicate when it comes to charging. You can't just hook it up to a power supply and let it charge. The charge must be controlled by a circuit that can sense when the battery is approaching capacity and shut off the current.
The battery will overheat quickly past 100% charge, and the pressure inside will spike steeply, causing the casing to rupture or explode.
These types of batteries like a three-stage charging scheme. A fast charge rate gets it to 80 or 90% charge. A timed charge tops it off, then a trickle charge "floats" the battery. This is a pretty complicated circuit, and will requires some form of IC control. I suggest you find out who manufactures the battery and contact them to obtain a proper charger.
Wiring the battery to the power supply will drastically shorten its life unless you carefully control the charging time.
Old 05-09-2009, 10:02 AM   #5
It was a dark and stormy
Yoyizit's Avatar
http://www.google.com/search?hl=en&s...es&btnG=Search
Charging at a constant current C/100 rate (16 mA) may be OK or it may not do anything.
More On This Topic
A capacitor stores an electrical charge between two conductors (plates) separated by an insulator (dielectric). This is similar to a battery, although a capacitor is used only for temporary storage of the charge. The following steps will show how to... Read More »
Garden paths and creek bridges are delightful areas to spend summer evenings with family or friends. Lining these areas with solar-powered lights allows guests to stroll safely through an unfamiliar garden at night. Gnomes are night time creatures and an... Read More »
The remote control dies and you are suddenly frantic, searching the house for a couple of batteries. You're opening cameras, old Walkmans, any piece of portable technology you can find just to get a couple of AA batteries... Here's how to make your... Read More »
Video production is easy if you have the right equipment. Learn tips for charging the battery in a video camera in this free video clip about the basics of a Canon XH A1 video camera. Read More »
Just because your tractor works on an 8-volt battery doesn't mean you have to scour the city to find a brand new one every few weeks. Instead, take the time to learn how to charge your battery to extend its use, and then buy a battery charger at your... Read More »
Arcade machine power supply runcmd3 Electrical 11 03-15-2009 07:44 PM
New dishwasher needs power supply. lupien Electrical 8 01-16-2009 09:58 PM
test new power supply? darsunt PC Repairs & Upgrades 8 09-08-2007 08:04 PM
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
