Old 12-26-2011, 06:39 PM   #1
custom cover for light switch buried in wall
On one of the first light switches I wired I put the box too far back into the wall, and now, with the cover on, the switches are too far back to reach through the holes. I'm wondering if they make switch covers that, rather than protruding out just beyond the wall, like most do, sink into the wall maybe 1 cm to work in this situation? Has anyone seen anything like that or have any ideas where I could look? Obviously I've already checked my local hardware stores.
adamgram is offline   Reply With Quote
Old 12-26-2011, 06:44 PM   #2
jproffer's Avatar
Either way, with the box that far back from the wall surface, it's not legal. It needs to be re-worked to pull the box (and naturally, then the switches) out farther.
jproffer is offline   Reply With Quote
Old 12-26-2011, 06:47 PM   #3
What does the code say about that situation? I guess if it violates code that would explain what I can't find a switch to accommodate it. I'm not ripping the wall apart again. If I can't find a switch cover that will work I'm going to chip away at the plaster so I can fit a standard switch cover back where the box is.
Old 12-26-2011, 06:47 PM   #4
There called box extenders. Any Lowes or Home Depot will have them. http://www.amazon.com/Carlon-PVC-Ele.../dp/B000H5ZVY8
Old 12-26-2011, 06:53 PM   #5
jproffer's Avatar
HA, didn't even think of that Joe.
I'm glad that's not something I was doing because I would have took the box out and pulled it forward.....and when I was done, THEN I would have remembered those little jewels......oops.
Says the outside of the box can't be more than....I think 1/4" (pros...confirm/deny??)...behind the wall surface.
Old 12-26-2011, 06:53 PM   #6
AH! I saw those in the store but I didn't understand what they were for. I can just get longer screws, use one of these to fill the gap, and I can pull it out. I'll have to pull the switch out, but I won't have to re-wire anything or move the box. Thanks!
Old 12-26-2011, 07:14 PM   #7
Electrical Contractor
It comes with the screws, 2 inch I think.
If you need longer screws, then you may need to rethink pulling the box out.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-26-2011, 07:50 PM   #8
Licensed electrician
The max 1/4" setback is for non-combustible surfaces. If a combustible surface the box needs to be flush or protrude from the wall.
Old 12-26-2011, 08:03 PM   #9
jproffer's Avatar
Good to know. So I assume drywall and plaster are both considered non-combustible?
Old 12-26-2011, 08:44 PM   #10
Exactly
Techy is online now   Reply With Quote
Tags
light switch
Help with wall switch - Constant voltage gambit023 Electrical 6 10-18-2011 10:30 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 03:44 AM
Replacing a wall outlet dimmer switch with a rocker switch Lonepine Electrical 1 01-05-2010 11:18 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
