Current Through Neutral Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2007, 01:48 PM   #1
Current through neutral wire?
Hi, any one can help !!!
my problem is : 3 phase 4 wire system with balanced load VL 400 V and Z 59+j36.5, i get IP 3.329 A in each phase and the current through neutral will be ZERO , but IF u disconnect one phase the current will change in neutral wire : i use multisim and i simulate the circuit and when i disconnect the phase i get 3.329 A in neutral wire , but how can i get same value by calculation i try and i get 2.88 A something like that , so any one have any idea how to calculate the current after disconnecting one phase ? , i would realy be thanks full .
saraf28 is offline   Reply With Quote
Old 11-29-2007, 04:06 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hi
I'm way to rusty with the phasor stuff but may be can get you steered in the right direction with another approach. So looking at the attached image....
The one equation is for an unbalanced system the other is a balanced system where In = 0. If I'm balanced and I close the switch in the neutral nothing happens no current flows and In =0 an Vn =0. If I remove one of the phases in the equation I am no longer balanced and current must flow in the neutral when I close the switch. If I remove V(cn) and in turn eliminate I(c) my equation becomes
I(a)+I(b) = I(n) so I'm not sure how you solve that using the phasor calculations but maybe this helps....
Old 11-29-2007, 04:23 PM   #3
Electrician
Rewards Points: 802
I can't answer your question but it doesn't sound like something a DIY would ask. Try out the sister site http://www.contractortalk.com and they may be able to help you out.
darren is offline   Reply With Quote
Old 11-29-2007, 04:47 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Or maybe he is a student looking for an answer to a test/exam question.
The M O of asking a question like this as your fist post is pretty typical.
Old 11-29-2007, 07:23 PM   #5
yeah thats right i am a student and this question is a tutorial we had it in the lap and i had aruge with my friends about it, so i deside to ask about it , in the end its knowlege, if it was an exsam why i should bother my self and other to get the answer, i have 7 brothers and all of them are engineers so any one can help out but as i say maybe my question will help be useful knowlege, thanks all any way.
Old 11-29-2007, 11:28 PM   #6
Once fried, twice shy.
elkangorito's Avatar
There are 2 ways to calculate this;
1] use phasor diagrams.
2] use polar or rectangular coordinates.
Also, bear in mind that in a multiphase system, the neutral current can only be zero Amps if;
1] the current in each phase is equal.
2] the Power Factor of each phase is equal.
Harmonics cannot be accounted for in this simple calculation.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Is it possible to add a 4 way switch to this configuration? irich Electrical 55 11-25-2007 09:15 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Sub feed house from new garage JAYRAN Electrical 10 10-02-2007 06:08 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
