Current Sensing Relay - Multiple Loops - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 03:17 PM   #1
Current sensing relay - multiple loops
I want to turn on a light and have this also energize a seperate circuit. I was thinking of using a current sensing relay to do this but the one I am looking at has a trip point of 1.5 amps which is greater than the current that the light will draw (0.4 amps). If I loop the wire through the current sensor 4 or 5 times will this work to make the 0.4A current appear to be 1.6-2.0A to the sensor?
jboyton is offline   Reply With Quote
Old 02-27-2013, 03:54 PM   #2
Engineer
Rewards Points: 161
What is the seperate circuit you wish to trigger?
diystephen is offline   Reply With Quote
Old 02-27-2013, 03:55 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,852
Yes, it would. But that is not the easiest way to accomplish this. Do you need the second circuit to come on only when the light is actually lit (in other words, not come on if the lamp is burned out)? If you don't need the second circuit to actually indicate proper function of the light, then you should probably just use a regular relay instead of a current sensing relay.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
diystephen (02-27-2013)
Old 02-27-2013, 08:03 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Yes, this will work, and is done on a regular basis.
micromind is offline   Reply With Quote
Old 02-27-2013, 10:55 PM   #5
The seperate circuit is just another light. Basically, I want a second light in another location to go on when I throw one of the two switches (it's a 3-way) that controls an existing light. I could rip out the wall to accomplish this but I'd rather not do it that way. It's easy to access the wiring to one of the switches, but not to the other switch or the existing light.
I guess most people would simply install a motion sensor. But I want the light to go on when I flip a switch, not when it senses movement.
So can I use a regular relay instead?
Old 02-27-2013, 11:38 PM   #6
Missouri Bound's Avatar
It will work. I"ve done a similar thing when measuring the amperage of a thermostat wire, which is below the lowest setting on the ammeter.
Do you want it your way or the right way?
Old 02-28-2013, 06:58 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yes. and the current sensor directions tell you this.
Old 03-01-2013, 01:29 PM   #8
Okay, thank you.
One person above suggested that a regular relay could be used. Is this true? Wouldn't there be enough of a voltage drop across the relay coil to make it unworkable to put it in series with a light?
Old 03-01-2013, 02:39 PM   #9
Rewards Points: 776
You wouldn't put it in series. Light wouldn't work.
You would put coil in parallel with bulb.
Since you already have current sense relay you might as well stay on course.
Be sure relay is UL listed and properly mounted or enclosed.
curiousB is offline   Reply With Quote
Old 03-01-2013, 04:44 PM   #10
Okay, thanks. That's what I thought.
I can't put a relay in parallel with the bulb without ripping out the wall. If I could put it in parallel I wouldn't need any sort of relay, I'd just put the other light in parallel with the existing one.
It's got the little "UL" on the outside. I'm planning to put it inside a junction box.
Relay controlled baseboard heaters a7ecorsair Electrical 6 06-20-2010 02:31 AM
Water sensing relay switch 110V gkern Electrical 4 03-30-2010 08:18 PM
How does a current sensing relay work? forresth HVAC 12 03-22-2010 12:25 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
newbie...relay problems jfabes Electrical 11 05-06-2008 05:48 PM
