Current Limiting Resistor - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 11:09 AM   #1
Current limiting Resistor
Hi there,
I recently built an aquarium LED light which went pretty well, however i read that I need to include a current limiting resistor into to the circuits.
I basically have used a constant voltage supply outputting at 12 volts and then ran 4 sets of series strings running in parallel with each other.
I am using a combination of cool white, royal blue and standard blue 3 Watt LEDS. I know that each LED will receive 4 volts each. So I did not include a resistor as this is about right for the LED as the specs of each essentially the same. However since building the light I have read that you always should add a resistor with any LEDs, however I can't see why this needed as I don't need the voltage dropping at all? I also read this was to limit the current, however I can't see how this works and obvious it seems more efficient not to include resistors?
Could anyone clear this up for please as I don't want to blow anything.
Oh the the specs for the LEDs are here :
http://stores.shop.ebay.co.uk/Future-Eden
The type of driver is like this
http://www.ebay.co.uk/itm/LED-Strip-...item33833ae82e
Many thanks in advance for anyone takes the time to reply.
Best regards
Jack
Jacks2High is offline   Reply With Quote
Old 07-20-2014, 04:29 PM   #2
Originally Posted by Jacks2High View Post
Hi there,
Best regards
Jack
Anyone???
Old 07-20-2014, 05:11 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 818
Need to confirm one thing....
How many LED's in series?
ddawg16 is online now   Reply With Quote
Old 07-20-2014, 05:43 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,096
It is never a good thing to run LEDS flat out for long periods,
It's a sure recipe for a a short life span.
Are you sure 4 volts is right for those leds ?
Most leds I have seen are around 3.5v max.
Try running less leds in each string then include a current
limiting resistor, reduce the current to approx 3/4 of max
this way you still get good light output and a much longer life.
dmxtothemax is offline   Reply With Quote
Old 07-20-2014, 05:52 PM   #5
Hi there,
Thanks for this.
If you look on the spec on the listing that is
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
I like the idea of just adding a resistor but not sure how to work out the resistor value? I have used those online resistance calculators before but not sure if they are accurate.
Basically what I would like to know is if I had 3 LEDs in series (as per the spec for the cool whites above) what resistance value would I need for it safe with a current limited to 700 (max 750mA) according to the spec.
Sorry for all the questions?
Many thanks
J
Old 07-20-2014, 08:46 PM   #6
Use a one ohm resistor five watts power rating.
For 3 x LED's on a 12v supply.
Expect the resistor to be a little warm.
And allow for that when you mount the resistor.
Old 07-20-2014, 10:16 PM   #7
Rewards Points: 201
I don't know but here's a point
Since the box you have is sold as an LED driver maybe it has current limiting built in. I don't suppose it came with documentation?
If you need a resistor, size it so that V=IR where V is the voltage it has to drop (supply voltage minus sum of LED voltages) and I is the amount of current you want going through the LEDs.
As said above, install it with the understanding that it will generate heat.
Run and find ou is offline   Reply With Quote
Old 07-20-2014, 10:43 PM   #8
The resistance across an LED will change in relation to the temperature of the LED Junction...
As the junction warms up, the resistance value drops causing more current to flow across the junction.. The increase in current then causes the junction to heat up even more and further decreases the resistance which causes even more current to flow.. bla bla bla.. (see where this is going?)
Eventually, your LED becomes a flash bulb and goes supernova when it pops.
By installing a resistor in series with the the led, the resistor acts as a governing device and only allows a certain amount of current to flow. The excess energy it "governs" is converted to heat and dissipated.. (kind of wasteful but it works)
The specs on your led's vary via the link you provided.. However, if you provide a 1 ohm resistor rated for 1 watt in series with each string of 3 LEDS, you'll be pretty safe.
Also, I should point out that if you look at a graph that plots the input power as compared to output lumens, you will find that LED chips are most efficient at around 70% of their rated current..
Constant voltage drivers are NOT very good for led systems. They waste a lot of energy and can cause rapid cascade failures without the current limiting resistor in place.
Constant current drivers are BY FAR the best way to go.. (Meanwell is a good quality example) They greatly simplify installation, use energy much more efficiently, and pretty much eliminate any risk of cascade failure caused by thermal runaway.
Hope that helps,
PaulBob is offline   Reply With Quote
Old 07-20-2014, 10:45 PM   #9
Oh.. I should point out one other thing...
If you're going to spend the extra money on the "name brand" chips, just go to fasttech and get some CREE XML leds.. by far the best bang for your buck..
Old 07-21-2014, 05:04 AM   #10
This is all very good thanks guys, really appreciate your time and effort. Think I understand it now.
Think I will run a test with some 1OHM resistor rated at 10W just be safe (overkill but I can reuse them elsewhere)
Also I saw this which appears to regulate voltage and current via two pots. I think this would work as well - probably a better solution? Does anyone have any experience of some of these little modules?
Many thanks again for your help it really is so valuable
Old 07-21-2014, 07:19 AM   #11
Rewards Points: 1,684
10 watt is drastic overkill, and they're kind of big. Shouldn't need anything more than 1W
If you're running a 12 v supply and you're using 3W led's then
3 / 12 = 250mA
12 /.25 = 48 ohm
So the math says 48 ohms and I would raise that to about 50
(At 10 ohms you will supply 14 watts and blow the led)
Bob Sanders is offline   Reply With Quote
Old 07-21-2014, 07:39 AM   #12
Rewards Points: 3,256
If you can regulate the current that is all you need.
zappa is offline   Reply With Quote
Old 07-21-2014, 08:16 AM   #13
3 / 12 = 250mA
12 /.25 = 48 ohm
NO... Your math is correct but your formulas are totally wrong.. 1 Ohm at 1 watt is all he needs..
For some extra heavy duty measure, you could get a 2 watt (bigger) resistor.. But keep it at 1 ohm..
Old 07-21-2014, 08:26 AM   #14
This is what you want to drive all those led's.
http://www.ebay.com/itm/Mean-Well-MW...item4184265616
This is a wet location 48 volt driver that puts out a regulated 700ma.. It won't burn up your leds, its made by Meanwell (+1), and it is very simple to hook up so it eliminates a bunch of junctions and extra wires.
Hope that helps,
The Following User Says Thank You to PaulBob For This Useful Post:
mpoulton (07-21-2014)
Old 07-21-2014, 08:36 AM   #15
Hope that helps,
Great stuff, thanks for this. Really appreciate you taking the time for looking for me. I think I might just get one of these. Looks ideal!
Thanks again
Tags
aquarium lighting , led , led lighting
Current sensing relay - multiple loops jboyton Electrical 9 03-01-2013 04:44 PM
Electrical mystery - current on ground! braverichard Electrical 27 01-16-2013 07:33 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 04:11 PM
Am I Crazy? AC Current Less than 110 kahuna44 Electrical 8 03-02-2007 11:25 AM
