Cumins Standby Generator ATS - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 02:06 PM   #1
Cumins standby Generator ATS
I am planning on installing a Cummins Onan 13KW NG generator for a home that has an existing 150 Amp service. Plan to use the 200 AMP SE rated ATS. The home owner has converted some of his high load devices (oven/cooktop/dryer/water heater) to NGas. Does the ATS mentioned above have a load shedding/AC shedding feature so I can be NEC compliant? Cannot get an answer from Cummins. Thanks in advance.
benp63 is offline   Reply With Quote
Old 07-06-2013, 03:56 PM   #2
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
This one is compliant.....With the NEC...Welcome to the forum.
http://www.homedepot.com/p/t/2034771...specifications
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 07-09-2013, 05:46 PM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
This does not have load shedding ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 07-09-2013, 05:47 PM   #4
Rewards Points: 516
What is the load calc of the house ..?
Old 07-09-2013, 08:20 PM   #5
Load Calc for house
Thanks for your response. Running load is 13.7 KW. A/C is a 3 ton high seer Trane.
standby generator installation cost newhomenj Electrical 54 12-26-2012 07:16 PM
Kohler vs Generac standby 7474 Electrical 61 09-08-2012 11:01 AM
Natural Gas Standby Generator - Multiple Questions wildbilll Plumbing 3 01-17-2012 05:46 PM
Standby generator connected via detached garage? vsheetz Electrical 22 04-04-2009 02:44 AM
Definition standby power vs emergency power 8 Ball Electrical 2 09-06-2008 05:19 AM
