Crowded Light Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 09:55 PM   #1
CaptChaos's Avatar
Question
Crowded Light Box
Dear Electrical Experts:
I am replacing a wall fixture in a plaster wall in my circa 1915 home. Unfortunately, the previous fixture did not have a wall switch (it was controlled by a switch on the fixture itself). As a result, I am now installing a light fixture. In order to run the line from the fixture box to the (newly installed) wall switch box, I need some room in the box itself, but I am concerned that the attached box (picture attached below) is a bit too crowded as is. There a TON of wires in there, looks like two sets of 4 wires tied together with the red wire nuts. There are not ground wires as the boxes are grounded via the metal conduits (I believe). The black and white wires capped off with the yellow nuts were previously wired to the old fixture.
First off -- any idea on why there are so many wires in here? I know one is probably ingoing and one is outgoing. I'm guessing that means that the previous fixture was completing a circuit?
Second off -- is this box already overloaded? If not, I just need to one one more line to accomodate the switch? Will this be too much? If so, what are my options to expand this box?
http://img32.yfrog.com/i/lightfixtureboxmess.jpg/
Thanks,
Cap'n
CaptChaos is offline   Reply With Quote
Old 12-07-2009, 10:46 PM   #2
If you can open your hole size up, you can put a larger remodel box in and that would give you more space to work with. Just one idea , I'm sure you will get other opinions.
Livewire78 is offline   Reply With Quote
Old 12-08-2009, 07:05 AM   #3
That was probably leagl way back when, but it is just plain unsafe now. As suggested above, replace with an old work box. Make sure everything is dead before moving wires, and MARK EVERYTHING BEFORE DISCONNECTING, OR YOU WILL BE BACK HERE ASKING HOW TO MAKE IT WORK.
Old 12-08-2009, 07:29 AM   #4
300zx's Avatar
Post
Will the new light cover the round space you have there? Could you get that box out of there and install a round cut-in box.The cut-inbox will look like the one on the bottom with the wings to hold it in place ese
300zx is offline   Reply With Quote
Old 12-08-2009, 08:42 AM   #5
CaptChaos's Avatar
Thanks everyone - I am going to replace that electrical box today. I think that the fixture will cover the round box, so I will likely go for that.
One quick question -- do they make old work\remodel boxes in metal? I think getting a metal box is relatively important in my case to ground the metal conduit and with the plaster\lath wall a remodel box is going to be better.
Ok -- a Google looks like I should be ok:
http://homerepair.about.com/od/elect...bx_old_mtl.htm
The only pain with a circular box would be the need to cut an expanded whole in the lath, but not a big deal.
Thanks!
Cap'n
Old 12-08-2009, 09:18 AM   #6
300zx's Avatar
Thanks!
Cap'n
I don't think that box is going to give you the room you need! Look at the cu in electrical box for box fill.
Old 12-08-2009, 09:40 AM   #7
Rewards Points: 1,418
Back in the old days, it was not unusual to bring power to a box in the ceiling and branch off from there (octopus style) to all the receptacles in the room.
You may be able to find a ceiling light fixture that is large enough that some of the wires can spill out of the box onto the ceiling and be covered up by the fixture. But you may not string wires through a hole in the top plate of a light fixture, make the connections and splices within the fixture, and string the wires back out, up into the box to daisy chain elsewhere.
Old 12-08-2009, 09:59 AM   #8
Household Handyman
Rewards Points: 1,408
CaptChaos: I'm speaking from experience--My son bought a house built in 1921 some years back, with plaster walls, metal lath. During some remodeling we found exactly what you have, what I call "switch/receptacle boxes" used in the ceilings with more wire in them than I could have put in them. I changed the metal "switch/receptacle boxes" in the ceilings to plastic old-work ceiling boxes, like the one in the picture without the ring. I also added an extra box in the attic space to put some of those wires in so the newly added box was not so crowded. Cutting out the plaster and lath was not exactly easy but do-able. Be sure to secure your new, old-work to your existing ceiling joist for strength. Good Luck, David
Old 12-08-2009, 02:08 PM   #9
Rewards Points: 320
If this is bx cable then you cannot use plastic boxes. The box is grounded through the bx jacket. The old boxes tend to be small and are definitely overfilled by today's code. I would try to replace the existing box with a deep octagonal box. The box fill is calculated by the size of the conductors and the box size. Count all of the wires in the box and post back and we can help you figure out what you need.
teamo is offline   Reply With Quote
Old 12-08-2009, 02:25 PM   #10
300zx's Avatar
Post
Is this a wall or ceiling? If its a ceiling then you could use a fan brace box or make your own brace with a 2x4 nailed between the joist and then screw your metal box to it.
Old 12-09-2009, 07:36 PM   #11
CaptChaos's Avatar
Thanks Allan. In my case, this is a wall fixture, not a ceiling. I believe that I have found a box large enough to accommodate the wires that will be covered up by my new light fixture.
Old 12-09-2009, 07:37 PM   #12
CaptChaos's Avatar
Hi Teamo -- I have a total of 8 wires coming in, plus 2 pigtails to the fixture itself.
Tags
electric wiring , electrical box , old house renovation
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
