Crouse-Hinds Replacement Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 10:52 PM   #16
Rewards Points: 27
Originally Posted by 220/221 View Post
Murray/Siemans.....whatever it takes.
It looks to me like they come from the same factory/mold.
Someone once posted a pic of a Murray AFCI breaker in a Siemans package.
They are the same except for the listing, so I use Siemens in a I-T-E or Siemens panel, & Murray in a Murray or Crouse-Hinds panel.
Norcal is offline   Reply With Quote
Old 02-02-2010, 12:13 AM   #17
General Electric THQL breakers work fine in my Crouse Hinds panel.
eric_miami is offline   Reply With Quote
Old 02-02-2010, 07:24 AM   #18
Rewards Points: 27
You can use them, but they are not allowed to be used in Crouse-Hinds gear. Unless you have paperwork stating that a competing make of breaker has been UL classified to fit in a specific panel, you cannot use it.
Old 07-26-2010, 09:01 PM   #19
Bringing this thread back to life...I need to replace a breaker in the home we just bought. It is a crouse hinds breaker, and the sticker on the side reads MP2020, with a bar code underneath.
I have been told that there are new breakers that will interchange with the old, but I can't seem to find any type of solid information on what to get. The Box stores and www.lawoolley.com here in town were less then helpful.
I did find this breaker http://www.andersonsstore.com/Home-I...Breaker-20-AMP that looks pretty close, but I can't tell if it is exact or not... Just hopeing someone with a little more experiance can set me right here.
Thanks guys
willy0314 is offline   Reply With Quote
Old 07-26-2010, 11:17 PM   #20
Ok..so after some more searching around this is what I have come up with... Crouse Hinds was bought by Murray..or vice versa...and subsequently bought by Siemens. right?
So I have a Crouse hinds breaker labeled MP2020. I found a site that lists a Siemens Q2020 as a compatiable replacement. Subsequently Lowes sells Siemens breakers. Links below. So am I correct to beleive that the Q2020 breakers will replace the old crouse hinds MP2020 that I have now?
http://www.hardwareandtools.com/Siem...r-6943039.html
http://www.lowes.com/pd_12435-1318-Q...ProductDisplay
Old 07-27-2010, 08:05 AM   #21
47_47's Avatar
Rewards Points: 58
Try Davis Electric, they are in Cheektowaga.
47_47 is offline   Reply With Quote
Old 12-16-2012, 12:26 PM   #22
Send a message via ICQ to Pimbhiriumb
Google Search Wrodderse
Google Search Pimbhiriumb
LINK
Pimbhiriumb is offline   Reply With Quote
Old 07-01-2013, 01:59 PM   #23
what size breaker to use on a #8.aluminum
deasey is offline   Reply With Quote
Old 07-01-2013, 02:04 PM   #24
Rewards Points: 6,652
Any size you wish. Sorry, this is not a search engine deasey. You went theough a lot of work to unburry an old thread, sign up to post a question that you must have asked on some search engine, which returned this threa in the results.
Old 11-02-2015, 09:44 PM   #25
Rewards Points: 2
Just bumping this thread.
I have an old crouse hinds panel. still can't get a solid answer every company listed that has UL approved breakers have been bought by another company or bought a company and changed names. A person at Lowes told me that Eaton breaker will be fine in the panel but just wanted to make sure before i put it in?
anyone have any clue?
thank in advance.
petrgirg is offline   Reply With Quote
Old 11-02-2015, 10:28 PM   #26
Rewards Points: 27
The line was sold to Siemens, and it has reverted to it's original name, Murray, the breakers have changed in appearance but still has the "MP" branding, Eaton may be UL classified to be used in Crouse-Hinds/ Murray panels but need paperwork to prove it.
Original equipment breakers are UL listed, some competitive breakers are UL classified to be used in other manufacturers panels, Eaton is one who makes UL classified breakers, SQ D is at the other end, none of their products are classified to be used in other manufacturers products.
The Following User Says Thank You to Norcal For This Useful Post:
petrgirg (11-02-2015)
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
Replacement of breaker Spraiski Electrical 6 11-27-2006 08:45 PM
breaker replacement maintenance Electrical 2 09-30-2004 07:28 PM
