Crossed Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 09:47 AM   #1
Crossed circuit
I believe that I have a crossed circuit situation in my home: it requires two breakers to switch off power across three rooms, but switching on either breaker re-energizes all three rooms.
I would like to locate the source of the problem, but it is unclear what, exactly, I am looking for? Based on my reading of the various crossed circuit posts in this forum, it seems there may be multiple causes.
Thank you!
Ricky650 is offline   Reply With Quote
Old 02-16-2013, 09:54 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would call an electrician for this one. This is not going to be easy for a homeowner without electrical experience. You are going to end up taking multiple boxes apart and leaving them apart until you find the problem.
Like demolition, taking apart is easy. Its the putting things back together that is going to be the difficult part.
If I was to guess, I'd guess the problem is in a multiple gang switch box, or a previous owner had a problem, and the trouble circuit was re-fed, and now you have two feeds.
Old 02-16-2013, 09:57 AM   #3
k_buz's Avatar
I'll add to my last post instead of editing it...
The problem could be absolutely anywhere on those two circuits. In order to trouble shoot this, power will need to be on, and that alone says "Call a professional".
The Following User Says Thank You to k_buz For This Useful Post:
J. V. (02-16-2013)
Old 02-16-2013, 01:57 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
I had a customer with that problem.
He had just bought the house and noticed he had a tripped breaker, but everything worked.
He reset the breaker and it tripped again.
I went over, disconnected the breaker and the wire sparked as it hit the panel and tripped another breaker.
Took me several hours to find the problem.
jbfan is online now   Reply With Quote
Power in circuit, but not at outlets Sandmonkee Electrical 15 01-20-2013 01:11 PM
electrical light circuit crossed with recept circuit shakydoctor Electrical 7 01-01-2013 09:43 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 10:38 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
