Cross Talk On Mwbc Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 04:06 AM   #1
cross talk on mwbc circuit
I have a mwbc where one is running my kitchen outlets, and the other is running a dedicated circuit for the disposal. the breakers are adjacent in the panel, so they are on opposite phase and share a common neutral and ground. I was updating the outlets and so turned off only one of the breakers. when I tested the line to make sure it was off, my voltmeter still read about 10 volts. Is this normal? there were no appliances connected to either circuit.
emty22 is offline   Reply With Quote
Old 03-14-2012, 04:26 AM   #2
Rewards Points: 3,256
Yes, that sounds normal. The combination of a high impedance meter input and inductive coupling in the AC wires causes this. If you were to plug a lamp into one of your kitchen outlets while the breaker is off the voltage should disappear as you are placing a low impedance path from the hot to a grounded conductor.
It is good practice to turn both breakers off when working on a MWBC.
zappa is offline   Reply With Quote
Old 03-14-2012, 07:42 AM   #3
Rewards Points: 2,512
hammerlane is offline   Reply With Quote
Old 03-14-2012, 07:55 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
For sure! A MWBC is NOT DEAD unless both breakers are off.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
SD515 (03-14-2012)
Old 03-14-2012, 09:10 AM   #5
Ravenworks's Avatar
I thought MWBC circuits were to have ties on the handles by code? At least thats what you guys taught me.
Ravenworks is offline   Reply With Quote
The Following 2 Users Say Thank You to Ravenworks For This Useful Post:
J. V. (03-14-2012), mpoulton (03-15-2012)
Old 03-14-2012, 09:16 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Depends on the code cycle when installed.
jbfan is online now   Reply With Quote
Old 03-14-2012, 12:54 PM   #7
Thumbs up
thanks
thanks for the assurance. this house was built in 1976, so at the time no breaker bar was required.
thanks again.
Tags
crosstalk , mwbc
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Planning circuit layout for barn tbeaulieu Electrical 8 04-08-2010 10:38 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
