Crooked Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2007, 07:53 AM   #1
crooked outlet
I hope someone could clear this up for me. I've read that outlet boxes can be no more than a 1/4" below the wall face, but does this apply to all types of walls?? For instance, wood is much more combustible than drywall and ceramic tile is practically impossible to ignite with sparks. Also what if the outlet is near a corner where the spackle causes one side of the box to be recessed, sometimes more than a quarter inch?
farrington135 is offline   Reply With Quote
Old 07-29-2007, 09:38 AM   #2
Master Electrician
JohnJ0906's Avatar
If the surface is combustible, The box must be flush, or project from the wall. If non-combustible, 1/4". "Add-a-depth" rings are made for this.
The NEC says "concrete, tile, gypsum, plaster or other non-combustible surface" 314.20
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 08:22 PM
outlet made a pop, spark, tripped breaker-need to fix louisemr Electrical 1 06-13-2007 07:58 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
