Old 08-30-2012, 08:36 PM   #31
E2 Electrician
stickboy1375's Avatar
Critique my Kitchen Wiring Schematic
Originally Posted by Rochsolid View Post
Why do you have GFI everywhere? In Canada's they are only required if you are within 1.5m o a sink. Also I would run 12/2 to my counter plugs, 20 amp breakers and split T receptacles
Probably because the OP is in the USA, and every receptacle serving the countertop must be GFCI protected... but we dont need silly 20 amp receptacles...
Old 08-30-2012, 08:42 PM   #32
Electrical Contractor
The US code requires every counter top receptacle to be gfci protected.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-31-2012, 12:48 AM   #33
" Euro " electrician
frenchelectrican's Avatar
Basically the same way in France. also 20 amp circuit beside the fridge can use 16 amp circuit but the lights have to be on other circuit either 10 or 16 amp circuit depending on conductor size.
Merci,
Marc
Old 08-31-2012, 08:25 AM   #34
Originally Posted by patented View Post
In an effort to derail my own thread, I saw that First Alert has wireless "interconnected" alarms out now. They can be hardwired or battery operated. Anyone tried these as an alternative to the regular interconnected alarms?
I have 9 First Alert OneLink (wireless) w/voice smoke alarms in my house. Two are hardwired, seven are battery. A few are combo smoke/CO. Installed for a year, tested once a month, no problems so far.
My house (built 1984) had two hardwired non-interconnected smoke alarms when I bought it -- one in basement and one in hall on second floor. No alarms in bedrooms or main level.
silversport is offline   Reply With Quote
Old 08-31-2012, 09:04 AM   #35
Thanks for all the posts. I think I will look into the OneLink smoke alarms.
PS - I am in the USA (Missouri).
patented is offline   Reply With Quote
Old 08-31-2012, 09:44 AM   #36
Code05's Avatar
I do not see any wall receptacles.
Code05 is offline   Reply With Quote
Old 08-31-2012, 09:52 AM   #37
Licensed electrician
Nice catch Derek. I would have thought someone would have seen that awhile ago.
Call me.
Old 08-31-2012, 10:00 AM   #38
E2 Electrician
Im hoping they are existing and he's renovating the existing space?
Old 08-31-2012, 10:07 AM   #39
Code05's Avatar
Thanks.
Call me.
Will do.
Maybe. OP did not say.
Old 08-31-2012, 10:08 AM   #40
E2 Electrician
Thanks.
Will do.
I figured he didn't draw them in for a reason.... guess we'll have to wait and see.
Old 08-31-2012, 10:27 AM   #41
There basically arent any walls in the kitchen that do not have countertop/cabinets. The areas to the leftmost side of the diagram are "existing" wall spaces with outlets, but otherwise there are mainly just doors and stairwells separated by very short sections of wall.
There is one wall receptacle located on the top, middle wall, and one located at the bottom of the diagram. Thats about it though. Its a VERY open space, so all of the receptacles are basically ending up on the islands or above countertops.
I should note that the kitchen is basically in the middle of my house, so there are a bunch of openings to other rooms.
Old 08-31-2012, 10:52 AM   #42
E2 Electrician
You still need receptacles for the wall space, any wall that is 2' minimum , and fixed glass counts as wall space, but if it was all existing, I'm betting you are okay.
Old 08-31-2012, 11:06 AM   #43
This might help
Old 08-31-2012, 11:11 AM   #44
E2 Electrician
This might help
So are the spaces between the doors 24"? if so, are there receptacles there?
Old 08-31-2012, 03:03 PM   #45
The two toward the bottom left are 30" wide. One has a receptacle, but I will have to add one to the other.
Thanks for pointing this out!
Kitchen Wiring Clarifications sullivja Electrical 30 08-05-2012 09:20 AM
Can't figure out kitchen light wiring... 19mquinn79 Electrical 9 09-23-2011 05:55 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 06:51 AM
Wiring inside kitchen island? vsheetz Electrical 14 05-12-2009 02:49 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 05:06 PM
