Critique My Kitchen Wiring Schematic - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 08:39 AM   #1
Rewards Points: 77
Critique my Kitchen Wiring Schematic
I am remodeling my kitchen and am submitting for my permit next week (using homeowners electrical permit). Please take a look at my proposed design and let me know if it looks ok to code.
I have the lighting and receptacles wired on separate pictures for clarity.
Can the range and vent hood be on the same circuit? Do they need to be GFCI?
Can the dishwasher and disposal be on the same 20 A circuit?
Thanks guys!
Critique my Kitchen Wiring Schematic-slide1.jpg   Critique my Kitchen Wiring Schematic-slide2.jpg
patented is offline   Reply With Quote
Old 08-30-2012, 08:49 AM   #2
Rewards Points: 13,458
Smoke detectors need to be on there own circut.
Old 08-30-2012, 08:53 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No they dont... unless a state amendment exist, and they are actually smoke alarms...
But they also can't be on the SABC of the kitchen, feed the smoke off the lighting circuit.
The Following User Says Thank You to stickboy1375 For This Useful Post:
kevinp22 (08-30-2012)
Old 08-30-2012, 08:57 AM   #4
E2 Electrician
I would run a 12-3 to the sink cabinet for the DW and Disposal...
Old 08-30-2012, 09:00 AM   #5
Licensed electrician
Rewards Points: 1,502
Along with the the other smoke alarm comments, there is no way I would install one in a kitchen.
There can be no spot on a kitchen countertop more than 2' from a receptacle.
Is this an electric range or gas?
Old 08-30-2012, 09:03 AM   #6
E2 Electrician
Me neither... or outside of a bathroom for that matter.
Old 08-30-2012, 09:10 AM   #7
E2 Electrician
Old 08-30-2012, 09:24 AM   #8
Rewards Points: 77
Thanks guys. I'll run the smoke alarm off of the lighting circuit. I have a requirement in my jurisdiction that I have to include one. Also, the smoke devices are both detectors and alarms, as they must first detect smoke and then send an alarm when detected.
Stickboy, why the 12/3 to the dishwasher and disposal? I have no problem doing this, but am wondering what it would gain me?
I should be ok with the 2' between receptacles. The space on the far right-hand side of the kitchen, in the middle, is actually a window and a window seat, so there is no countertop right there.
Old 08-30-2012, 09:26 AM   #9
Rewards Points: 77
Oh, and the range is all gas, but with electric ignition. (the 240v outlet in the lighting diagram should be removed)
Old 08-30-2012, 09:29 AM   #10
E2 Electrician
The NFPA feels differently, but its a non issue.
For two reasons, one being, if your appliances call for dedicated circuits, the second reason in case you add an appliance later on, insta-hot etc... easier to run that spare wire now... and it wont cost you much more. And I would pull this wire to the actual sink cabinet and install a cord on the dishwasher.
Old 08-30-2012, 09:33 AM   #11
Rewards Points: 77
Thanks, that makes a lot of sense. If they call for separate circuits, I assume you are saying I can use a common neutral and then run the red and black wires to separate breakers at the panel?
Thanks again, you guys are a huge help.
Old 08-30-2012, 09:36 AM   #12
E2 Electrician
Correct with the breaker situation.
And you could just break the tab off the duplex receptacle and have two circuits on one duplex receptacle...
Old 08-30-2012, 09:38 AM   #13
Rewards Points: 77
Another good suggestion!
Old 08-30-2012, 09:39 AM   #14
Will this smoke alarm be tied into the other ones in the house? Do they require you to bring the entire house up to todays smoke alarm code?
Old 08-30-2012, 09:43 AM   #15
E2 Electrician
I know around here they cant force you do to that, but the OP will have to check on what they actually require...
Kitchen Wiring Clarifications sullivja Electrical 30 08-05-2012 08:20 AM
Can't figure out kitchen light wiring... 19mquinn79 Electrical 9 09-23-2011 04:55 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 05:51 AM
Wiring inside kitchen island? vsheetz Electrical 14 05-12-2009 01:49 PM
Kitchen Wiring Questions Chazbe Electrical 22 04-11-2008 04:06 PM
