Is A Crimped Neutral Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 07:38 PM   #1
Special User
Rewards Points: 1,230
Is a crimped neutral code?
House in Idaho, US built in 1971. I'm installing a bathroom vanity light fixture on the wall and unwrapped electrical tape to find the attached crimped neutral connection. Looks like this was done when the house was built, as the electrical tape wrapping the crimp still had drywall mud splatter on it. Code? Rip out and wirenut, or leave be? The ground connection is like this too. Thanks,
tylernt is offline   Reply With Quote
Old 07-11-2012, 07:45 PM   #2
Licensed electrician
While those crimps are fine for a grounding connection a connection for a neutral should have been insulated.
Those conductors were cut way too short.
Old 07-11-2012, 08:36 PM   #3
joed's Avatar
Rewards Points: 11,518
Wire nut the connection.
Old 07-11-2012, 08:41 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Good thing they put that extra piece of insulation back on after the crimp...
Old 07-11-2012, 09:14 PM   #5
liscenced electrician
Rewards Points: 538
Take it for what its worth but I guarantee every connection in your entire house is made the same way.
jimmy21 is offline   Reply With Quote
Old 07-11-2012, 09:22 PM   #6
E2 Electrician
No doubt...
Old 07-11-2012, 10:47 PM   #7
Special User
So... these were code-approved in 1971?
Old 07-11-2012, 10:54 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't believe so. I also don't believe that romex is original...I think it had been added at some point after the home was built.
Old 07-11-2012, 11:11 PM   #9
Master Electrician
that's what we call a buchanan crimp. It takes a special four point crimper to crimp them right. Still use them everyday at work. It's considered a better connection than a wirenut and when they actually will let us make joints on fire alarm systems that's how they have to be done. What's missing from the picture is the little plastic cap that pops over the crimp to insulate it. Once the cap is pushed on you can't take it back out. They're about as permanent a connection as you can get without welding or soldering.
edit: to answer your question it is a code approved method of splicing but definitely not if it's left bare. you can buy the caps seperate from the actual crimps so that may be something you look getting, much cheaper to just wirenut it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following 3 Users Say Thank You to andrew79 For This Useful Post:
Evstarr (07-12-2012), gregzoll (07-12-2012), tylernt (07-12-2012)
Old 07-12-2012, 08:35 AM   #10
Rewards Points: 6,652
Majority of the homes built in 1971 in my area have the Buchanan crimps on various junction points. As Andrew stated, good solid connection, better than wire nuts. And a lot quicker to do than wire nutting.
Old 07-12-2012, 06:01 PM   #11
E2 Electrician
Not to start a fist fight here, but I don't see how that crimp is 'better' than a wire nut, I consider them the same, but different. I still use ground crimps because they are 'easier' not 'better' to install. okay, back to are normal programming.
Old 07-12-2012, 06:28 PM   #12
Master Electrician
that crimp won't ever come apart, you have to cut it to separate the wires. Any number of things can go wrong with a wire nut, the inside can come loose from the outside, wires can be pulled out if not done right, wires can break from over twisting. Granted a professional should never have an issue with a wirenut but it does happen sometimes. Better may not be the right word, less margin for error is probably a better way to put it. Electrically speaking the connection is no better either way
Old 07-12-2012, 06:30 PM   #13
E2 Electrician
Hogwash, both are only as good as the installer, you know how many people install these by just squeezing down on them with pliers? They would be better off using a wire nut.
Old 07-12-2012, 06:57 PM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
That was and is still legal.
Have you ever seen soldered connections?
I'm not saying I would do it, but I have seen it many times.
jbfan is online now   Reply With Quote
Old 07-12-2012, 07:13 PM   #15
E2 Electrician
I have seen a pigtail installed with a cap, which is legal, I don't see how taping the crimp is acceptable....
http://www.idealindustries.com/media...-insulated.jpg
Any code involving downsizing Neutral and Ground for a subpanel? forresth Electrical 1 05-17-2012 09:34 PM
Lost Neutral on K&T Circuit RST Electrical 4 11-29-2011 12:25 PM
square d panel neutral bar question pdxrain Electrical 7 11-28-2011 12:28 AM
Induction Cooktop, no neutral (?!) andersol Electrical 7 09-28-2010 04:47 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
