Crimped Grounds Too Short - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 03:37 PM   #1
Rewards Points: 160
crimped grounds too short
When I need to tap into a box with crimped grounds, I just cut the wires at the crimp and splice in the new one with a wire nut. But in my house (1975) the crimped grounds are only about 2" long and in some cases even shorter. No way I can figure out to use wire nuts on them. So I add a new box somewhere near the old one, splice in some new cable and fish it to the old box. The new box gets a blank wall plate. But it's a pain and the blank wall plates don't exactly add to the decor.
So, is there any better way to deal with these "too short" crimped grounds? I doubt there's room to use wire nuts on each ground wire individually, in order to make them longer. I guess one solution is to buy a crimper, use crimps to extend each wire. Ugh. Other solutions?
philS is offline   Reply With Quote
Old 10-21-2012, 03:52 PM   #2
Rewards Points: 342
These may work -
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
tribe_fan is offline   Reply With Quote
Old 10-21-2012, 06:45 PM   #3
Rewards Points: 160
Originally Posted by tribe_fan View Post
I've heard of these but never used one. I assume they work better than receptacle backstabs. Are they smaller than a yellow wire nut? If so they might just work. Still, a crimp would take up less space because the pigtail can continue in the same direction as the old wire. But thanks. I'll have a look.
Old 10-21-2012, 09:55 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I used them pretty often over here in France and I have no issue and yeah they are smaller than yellow wirenuts but eaiser to use them and they don't cost very much but it do justifed the cost when you get them.
also it known as Wago connector it simauir to the Ideal as you did hit the link.
So either way will work.
And get couple short peices of extra conductors you will need them anyway.
Merci,
Marc
Old 10-22-2012, 09:26 AM   #5
Licensed electrician
Rewards Points: 1,744
Those connectors in that link are great for your problem. You can hold the ground with needle nose pliers to insert it in the connector.
Bryant Furnace short cycling...help! Spark Chaser HVAC 12 04-06-2016 08:16 PM
Furnace short cycling repman55 HVAC 12 01-21-2011 04:41 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 12:54 PM
I caused a short in one room - now what? taychas Electrical 6 11-08-2006 04:02 PM
