Old 11-27-2007, 07:24 AM   #16
Once fried, twice shy.
elkangorito's Avatar
To crimp or not to crimp?
Just curious...have you guys got a pic of the crimps you use?
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 11-27-2007, 10:18 AM   #17
Electrician Apprentice
puma1277's Avatar
puma1277 is offline   Reply With Quote
Old 11-27-2007, 11:02 AM   #18
a box of wirenuts takes up alot more room than a package of crimp rings...
You MUST carry wirenuts
Crimps are optional
I'm just sayin
220/221 is offline   Reply With Quote
Old 11-27-2007, 11:53 AM   #19
Floor Sweeper
guys,
I was helping my uncle in his older house where the original installer used crimps on the current carrying conductors also. They used insulating caps on the crimps. The water heater was also connected using these. We replaced the water heater and had to cut the crimps. I bet it was a much more solid of a connection than a wirenut. Less chance of "heating up."
No hard feelings speedy. Sometimes "stirring the water" brings up even more thoughtful discussion.
junkcollector is offline   Reply With Quote
Old 11-27-2007, 12:33 PM   #20
Electrical Contractor
Originally Posted by junkcollector View Post
guys,
Don't bet on it. It all starts with the installer. I have found the same crimps, taped over and wires burnt.
The connections are only as good as the installer.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 11-27-2007, 12:51 PM   #21
J. V.'s Avatar
I love crimpsleeves. Do they still come with the rubber boot and hole to wrap under between wires then over? My only concern was that pesky little wire poking out of the boot. But I see they are now like a barrel instead of being open on both ends. I wish I would have thought of them when I rewired my complete house. I would have used them for all connections.
Old 11-27-2007, 08:13 PM   #22
Floor Sweeper
When you think about it, that goes for any type of connection: Wire nuts, splitbolts, terminal lugs, etc.
In the case that I mentioned, I did not see any signs of overheating.
Best way to crimp small disconnects Alpha Crow Electrical 15 10-13-2007 09:04 AM
