Creating Mother-In-Law Apartment - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 03:54 AM   #1
Hello;
I'm thinking of converting most of the basement of a house into a mother-in-law apartment. I'd like to leave the area with laundry facilities to be common to both the main house and the apartment. It occurs to me that it might be a good idea (and might be required) to have the circuit breakers located in the common area. Currently they are in the mother-in-law part of the basement where the service enters the building.
The question is can I create a pair of sub-panels and move all (or most) of the breakers there? The idea would be to have one sub-panel for the apt and one for the rest of the house - the circuits are pretty well separated by floor.
Would I be correct in assuming that each sub-panel would need a breaker at the main panel? Or could I get by with a disconnect switch at the main panel and move all breakers to the sub-panels?
Sincerely;
Michelle
PS: Is the NEC available online? Hopefully for free?
Michelle96 is offline   Reply With Quote
Old 09-15-2012, 08:32 AM   #2
Master Electrician
Rewards Points: 3,870
Originally Posted by Michelle96 View Post
Hello;
Sincerely;
Michelle
Does your basement have a means of egress other than the stairs?
brric is online now   Reply With Quote
Old 09-16-2012, 05:21 PM   #3
Hello Brric;
There is a back door (its a daylight basement) about 24" above the basement finished floor in the common area and the garage door will be replaced with some sort of door in the basement apartment area.
So the upstairs tenant can exit normally thru the front door or the back door. The downstairs tenant in the basement apartment can exit via the a door into the common area (and thence thru the back door) or thru the door in what was the garage. (By the way, there are windows in the basement of sufficient size to serve as emergency exits.)
Old 09-16-2012, 05:30 PM   #4
Master Electrician
Hello Brric;
Excellent.
AC not cooling sufficiently in 600 sqft apartment rmb HVAC 9 08-07-2012 10:09 AM
Advice on Acrylic smell/fume in my apartment bolland General DIY Discussions 1 10-12-2010 11:08 AM
Question regarding installation in apartment jwillis3000 HVAC 1 02-10-2010 11:45 PM
HELP old apartment .. Return Duct / Heat pump thethrowdown HVAC 1 01-29-2010 03:36 PM
25 Things My Mother Taught Me gma2rjc Off Topic 4 03-17-2009 08:44 PM
