Crawlspace Light Choice(s) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 01:38 PM   #1
I can tie my own shoes
algored2deth's Avatar
Crawlspace light choice(s)
I have a crawlspace that I would like to add lights to. The "ceiling" does not have drywall and I have no plans for it. The joists are 2x8, 16"O.C. I thought about using those recessed can lights at HD or lowes but I wanted to find out if that really is the right way to go here. The can lights seem to be meant for a finished ceiling. Otherwise, how do you put the light's trimwork in place? Do I go with the can lights or something else?
thanks
algored2deth is offline   Reply With Quote
Old 04-10-2011, 11:45 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Morepower26 View Post
Go with regular keyless lights.
Ya can do that but keep in your mind with very low height in crawl space you do not want have any open indentscent bulbs for safety reason.
If the OP want to keep the keyless socket then they can buy a safety cage to fit on the keyless socket to give more protection from the bulb get smacked out.
Something like this I know this is metal veirson but they do have plastique verison as well
Merci,
Marc
Old 04-11-2011, 06:31 AM   #3
Electrical Contractor
kbsparky's Avatar
Old-style "keyless" lights are sooooo 20th century.
Try using something more like this:
-KB
Old 04-11-2011, 08:37 AM   #4
I agree about limited head clearance using a keyless light in a crawlspace. Too much opportunity to hit the bulb while moving around. My crawl is about 4 ft tall. KB, can you provide a link to your suggestion?
I would prefer something that is recessed. Makes life a bit easier. I could probably get a one of those recessed lights and just put a little drywall around. Not finish the whole ceiling but just enough. It will look hacky but sometimes hacky is ok in my book.
Old 04-11-2011, 09:30 AM   #5
Licensed electrician
Rewards Points: 1,258
Besides the cost issue, you will only have 4' for the light beam from the recessed to spread out. The beam spreaed from a recessed is like an upsidedown ice cream cone. You will have very poor lighting in the crawl using recessed.
BTW, you would not need any drywall arounf the recessed either.
Old 04-11-2011, 10:04 AM   #6
Alright, recessed are out.
Old 04-11-2011, 09:16 PM   #7
kbsparky's Avatar
That is a Leviton 9860.
Here is one place that has them
Here is another one.
I have even seen `em at the loco Home Dee-pot.
-KB
Old 04-11-2011, 09:27 PM   #8
Too Short? Cut it Again!
I would use the new LED type florescent tubes. Near impossible to break. Long and thin in diameter. Reasonable light. Pricey though.
Old 04-11-2011, 09:32 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Just regular $2 sockets work fine, that's what I used. The cage things are a nice idea too if you can find them. Install a standard box, then add the sockets.
when I first moved in they only had 2 lights in the middle, so added 4 more by branching off the existing. Big difference.
Though I find because of a low ceiling light need to be placed closer. If I had money to burn I would actually put strips of neon lights between each joist, that would make a very nice even and clean light. You coudl probably hear spiders skurry away for dear life when you turn that on.
Old 04-11-2011, 10:11 PM   #10
Wire Chewer
Rewards Points: 68
Yeah CFLs are good enough, I like their bright white light. You could also put black lights and a disco ball if you want to host a midget rave party.
Old 04-11-2011, 10:27 PM   #11
I will probably go the el-cheapo route with the generic electrical boxes.
Red squirrel has a pretty nice crawl for being a crawlspace. Mine looks like a dump in comparison.
Old 04-12-2011, 01:45 AM   #12
Master of none
Instead of a keyless lamp holder with a cage, install pigtail light sockets. If this is unclear then I can post a photo tomorrow as I'm signing off for the day now.
handy andy is offline   Reply With Quote
Old 04-12-2011, 10:35 PM   #13
The pigtail socket is very loosely used in crawl space and I only used them for tempory useage for perament useage use the proper luminaire and be done with it.
Merci,
Marc
Old 04-13-2011, 08:02 PM   #14
The advantage of using a pig-tail socket in tight quarters is that if someone happens to bump into it, it will swing away, rather break the lamp or the socket.
Old 04-13-2011, 08:43 PM   #15
Wire Chewer
Rewards Points: 68
I go in my crawlspace all the time, I've never bumped into a light. Just need to be more careful in there.
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
