Craftsman Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 07:52 PM   #1
craftsman air compressor
i have a craftsman 33 gal air compressor in my shed it worked fine has not been used much now when i try n turn it on it blows the breaker doesnt try to come on just blows breaker right away
hopps is offline   Reply With Quote
Old 04-13-2011, 10:33 PM   #2
I=E/R
a7ecorsair's Avatar
Make sure the compressor isn't plugged in and then see if you can turn it by hand - this will tell you if anything is locked up.
The gallon size of the tank doesn't mean anything. What size (HP) motor is on the compressor, is it 240V or 120V?
a7ecorsair is offline   Reply With Quote
Old 04-14-2011, 11:15 AM   #3
Rewards Points: 56
Do as a7e suggested first. After that, if there is pressure in the tank, drain it down, and see if it will start; could be a bad check valve or unloader.
sears craftsman air compressor blacktrain Electrical 8 06-24-2010 12:54 AM
Bogged-down Craftsman compressor spavined Tools 14 03-05-2010 06:13 PM
Craftsman air compressor blowing breaker Frankenberry Electrical 38 10-10-2009 08:02 PM
Craftsman Air Compressor not pressurizing slingshot Tools 5 09-15-2009 08:10 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
