-   -   craftsman air compressor (http://www.diychatroom.com/f18/craftsman-air-compressor-101428/)
hopps 04-13-2011 06:52 PM
i have a craftsman 33 gal air compressor in my shed it worked fine has not been used much now when i try n turn it on it blows the breaker doesnt try to come on just blows breaker right away
a7ecorsair 04-13-2011 09:33 PM
Make sure the compressor isn't plugged in and then see if you can turn it by hand - this will tell you if anything is locked up.
The gallon size of the tank doesn't mean anything. What size (HP) motor is on the compressor, is it 240V or 120V?
DexterII 04-14-2011 10:15 AM
Do as a7e suggested first. After that, if there is pressure in the tank, drain it down, and see if it will start; could be a bad check valve or unloader.
