Craftman's 19.2 Charger Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:58 PM   #1
Craftman's 19.2 charger problems
My 19.2 charger is showing that the batteries are fully charged when they are put in and I know they are low. Is it the charger or the batteries?
denglish is offline   Reply With Quote
Old 05-27-2012, 09:14 PM   #2
It'd be good if you can monitor the battery voltage while in the charger by using two very thin wires or tin foil strips to bring out the battery terminals to where you can measure them.
Probably the internal resistance of the batt is very high because it's bad and so the charger thinks it is charged.
The batt can be checked for excessive internal resistance with a resistive load and a voltmeter if you have batt specs or another known good batt to check it against.
What battery technology? Nicad, Li-ion. . .?
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
How to connect my battery to my solar charger? rdlrn19 Green Home Improvement 0 02-26-2010 06:30 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Trickle charger on portable generator - bad battery? timp Electrical 5 01-01-2009 08:46 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
