Coxial Cable Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 02:13 PM   #1
Coxial cable help
I'm redoing all electrical in my 1901 Victorian and ready to pull coaxial cable but confused if I should get the standard RG6 or the RG6 quad kind.
I'm not sure what kind to use.
butterkups is offline   Reply With Quote
Old 02-12-2013, 02:51 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
Regular RG6....you don't need the quad
ddawg16 is online now   Reply With Quote
Old 02-12-2013, 02:58 PM   #3
Thanks. I'm just running cable for my HDTV in three rooms.
How about cable type for my Internet connection ? RG6 still?
Old 02-12-2013, 03:05 PM   #4
JOATMON
ddawg16's Avatar
Internet? I'm going to assume you have cable for both internet and TC.
Yes....that would be RG6 as well.
Assuming you have cable...a little background.
The internet portion of your cable typically sits on the upper freq spectrum of the bandwidth...close to 1Ghz. Hence, you want to make sure you use a cable splitter that has at least a 1Ghz freq range.
Typically, your cable comes in...goes to a splitter....one output goes to your cable modem, the other end to the TV or cable box. If more than one TV, then you will have a splitter with more than 2 outputs.
Caution, everyone of those output ports drops the signal by 3db (half power)...so if your using a 5 port splitter (4 outputs)...each output is going to only have 1/4'th power as your incoming signal.
Anyway....after your cable modem you have an Ethernet cable...this will either go to an Ethernet switch or, if your like most of us...a wireless router. For the Ethernet, Car5E or Cat6 is fine.
Hopefully I have totally confused you now.
Old 02-12-2013, 03:07 PM   #5
If you don't run the cable along power lines (I think you're supposed to stay 6" away) you probably don't need the quad. If you do, I personally think quad is a good idea. There's a lack of good information available to the general public about when quad is recommended. There's highly technical information about the effectiveness of different shielding, but that does the average consumer no good.
Dorado is offline   Reply With Quote
Old 02-12-2013, 03:07 PM   #6
Thanks. It was a big help.
Old 02-12-2013, 03:21 PM   #7
Rewards Points: 6,652
Pull Cat-6 for hdmi over Cat-6/ethernet wire. That way if you wish to locate the boxes in a central poit, vs at the hd sets themselves, it will make thing easy in the long tun.
Also helps if you have a smart tv at a location, you are already set.
sound out of cable box amakarevic Home Theater 11 05-18-2012 10:26 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 12:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 08:33 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
