Cover Modification For Older Murray Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 09:45 PM   #1
Cover modification for older Murray service panel
I have a 100 amp / 20 space Murray service panel that's about 25 years old. The cover has two holes at its bottom, for screws to hold it to the box. The box itself has 4 places where the metal was bent to form females for the kind of non-machine thread screws Murray used.
My question is this: did the cover forming machine FORGET to put 2 holes at the top of the cover? The cover can be hooked on at the top (sort of), but it doesn't hold very well - so, when you take the screws out at the bottom, the cover can easily fall off, into your lap, onto the floor.
I'm thinking about drilling the two 'missing' holes in the cover. Can anyone think of a reason NOT to???
Thanks in advance for any knowledge you can bring to bear on this.
JeffT is offline   Reply With Quote
Old 05-29-2012, 10:04 PM   #2
Licensed electrician
Rewards Points: 1,770
Some boxes may have a slot close to the top that the cover slides into and the screws just secure it in place.
plummen (05-29-2012)
Old 05-29-2012, 10:43 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Tags
load center cover
Upgrading Service/Moving Panel TheAcademician Electrical 17 09-13-2011 07:48 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
200 amp breaker in a 100 amp service panel? CalMag Electrical 5 09-12-2010 08:00 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 05:41 AM
