Cover/canopy For Routing Low-voltage Through A Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 12:34 PM   #1
Cover/canopy for routing low-voltage through a wall?
Hello folks, been lurking in this forum for a while so newbie here. I've been trying to figure out the proper way to route low voltge (for LEDs etc) through an interior wall to prevent exposing the cables, and so far I found a lot of useful information about using smurf tubes, etc.
However, I don't seem to see any instructions concerning what types of covers/canopies to use to bring the low voltage through the surface of the wall. Is there a standard cover/canopy that is used to bring low voltage out of the wall box? If so, does the cover/canopy have some sort of plug, or do the low voltage wires just come out of the cover/canopy?
Once again, newbie here so there might be obvious things that I don't know about yet. Any advice or links to photos/instructions will be appreciated!
Thanks,
- K.
klavatar is offline   Reply With Quote
Old 11-12-2011, 01:02 PM   #2
Licensed electrician
Rewards Points: 996
You should be able to find something on this link or you could use a plate and keystone jacks.
http://www.aifittings.com/catalog/communications/
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Bury Low Voltage Wire in Wall? Tool Junkie Electrical 3 06-16-2008 08:38 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
