Couple Wiring Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 09:47 PM   #1
Couple wiring questions
1. I've researched some websites about running wires and I haven't seen too much about standards for attics. I saw standards about basement and crawlspace. Can I run a length of board across the top/middle of my roof arches (as runner boards), run NM cable down either side, and above each room drop it down an arch into the room. Right now, my attic is a mess with cables run across the roof and some run and stapled on arches here and there.
2. I want to get my top floor rewired, right now plugs and lights from different rooms are mixed up on different breakers and almost all my kitchen is on one breaker. There are not any independant circuits for the oven, dishwasher, or refrig. (I'm remodeling the kitchen soon and want to have an electrican come in to take care of the rest of the house too) Most rooms have 3 or 4 plugs and one light. If I have a new cable for each room run from the panel to attic, can they use some sort of terminal block or junction to connect three outlets and one light together. I think it would take more wire to try and rerun a "loop circuit" around a room from the attic. I don't plan to tear up walls, I just want to run all outlets in one room to a central point and connect to the new feed. Twist and nuts would work, but I want something more like a junction box or terminal strip. I want to know what to ask the electrican about before getting quotes.
Thanks,
Charles
cmoe_1999 is offline   Reply With Quote
Old 03-22-2011, 10:47 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
Romex may be strung across attics almost with out restriction. Those restrictions are:
If the attic is used for storage then all wiring must be protected from damage with runner boards
If not used for storage then all wires within 6' of the access hatch must be protected.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
"switch loop" wiring questions latinomusician Electrical 7 06-16-2010 10:04 AM
Couple simple residential 2008 questions... tripflex Electrical 15 06-08-2010 10:27 AM
New detached garage, wiring, questions gp_wa Electrical 9 12-04-2008 03:10 PM
Basic Wiring Diagram Questions mfleming Electrical 12 12-03-2008 02:05 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
