A Couple Of Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2010, 11:05 AM   #1
A couple of questions
I am adding a new kitchen . I am trying to run a wire for an electric stove. The stove requires a 40 amp breaker.
1- what size wire do i need ?I am about 70 feet from panel ( I am thinking 6/3 cable with ground)
2- There is 20' section of my wire run where I have to be under slab. Can I just use direct burial cable and come up in a wall with a Junction box. and then continue the rest of the way in regular 6/3 wire?
3- How deep should the direct burial cable be? (I am thinking 18" )
Please if anyone can help I would appreciate it.
dweller10 is offline   Reply With Quote
Old 04-03-2010, 11:20 AM   #2
Master Electrician
if your actually below slab grade then i believe you can use a direct burial cable. If it's in the slab then you need to run a pvc pipe for the wire. Personally i would run the pvc pipe for future use and troubleshooting. A number 8 wire is all you need for a stove at that distance.
andrew79 is offline   Reply With Quote
Old 04-03-2010, 02:22 PM   #3
Electrical Contractor
kbsparky's Avatar
I would not recommend putting direct-burial wire under a slab. You could install PVC conduit under that slab. There is no depth requirement when you have buried the conduit under 2" or more of concrete, so it can lay at the bottom of the slab if desired. Just pour your concrete over the pipe.
#8 conductors, with a #10 ground should be sufficient for a 40 Amp range circuit.
-KB
Old 04-03-2010, 02:37 PM   #4
KB- I have only a portion maybe 20' that i will put in PVC. Rather not use a junction box if I don't have to. Can i run Romex in the PVC without any heat issues? and what size PVC should I use.
Old 04-03-2010, 11:17 PM   #5
kbsparky's Avatar
Sorry, you can't install romex inside of an underground conduit. The Code considers that a wet location.
-KB
Old 04-04-2010, 12:38 PM   #6
Master Electrician
nmwu could be run in the pvc though. I'm not entirely sure but to the best of my knowledge you wouldn't have to change your wire if you used it either, just come out of the pipe and right to your stove plug.
Old 04-04-2010, 05:00 PM   #7
jbfan's Avatar
Rewards Points: 528
Take emt back to the panel and change to pvc at the slab.
Old 04-06-2010, 07:10 AM   #8
What size pvc should I use? 8/3 with a ground. Could I use 1/2"?
Old 04-06-2010, 07:41 AM   #9
Just call me Andrew
Rewards Points: 1,020
According to this Raceway Fill Calculator, you need 3/4". You may want to run 1" should you want to run more at a later time.
Andrew
secutanudu is offline   Reply With Quote
Old 04-06-2010, 08:21 AM   #10
jbfan's Avatar
Rewards Points: 528
You can not run romex under the slab, as this is considered a wet location.
You can run uf, but not in 3/4 conduit.
you need to run induvidual wires inside the conduit, #8 thwn, with a #10 ground
Old 04-06-2010, 11:17 AM   #11
Cross section of 8-3 UF is larger -
You may need 1.5" conduit....I can't find a diameter size for that wire
Cross section is .8808
Better using single wires rated for wet use - THWN
Couple questions regarding Electrical Codes gregt848 Electrical 15 03-30-2010 02:03 PM
Couple of quick code questions re: placing receptacles tigereye Electrical 4 11-30-2009 03:42 PM
A couple of questions about stairs. Omega Supreme Carpentry 5 09-26-2009 06:07 PM
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
