A Couple Of Gas Pipe Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 05:45 AM   #1
Just call me Andrew
Rewards Points: 1,020
A couple of gas pipe questions
I just had a new condensing boiler installed. I put an outlet in near the boiler to plug in the condensate pump.
Can I zip-tie the pipe's power cord to the gas pipe (black iron) or is that somehow unsafe? It's a pretty heavy duty power cord.
Also, is this gas pipe supposed to be bonded to my panel somehow (or is it via the boiler's ground?).
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 12-17-2010, 06:59 AM   #2
Master Electrician
Rewards Points: 3,824
The power circuit supplying the boiler should have an equipment ground. If so, that equipment will provide NEC compliant gas pipe bonding. Local or state codes may require additional bonding. CSST piping is sure to require additional bonding. Zip ties no problem.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
secutanudu (12-17-2010)
Replacing 30 yr old duct... couple questions bigburb HVAC 7 06-11-2009 05:26 AM
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
A couple of Hardwood flooring questions drtbk4ever Flooring 12 01-24-2009 09:51 AM
couple questions about installing phone jacks joeyboy Electrical 31 10-09-2007 02:26 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
