Counting Wires In A Box? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 11:22 AM   #31
Household Handyman
Rewards Points: 1,408
There are many homes around here with the older plaster walls. I have used the box "secutanudu" described also. One trick I do is to replace the screws that come with this box with some that are 1/2" longer, that way I can back them out a bit longer to get them into those dang-blasted plaster walls, then they tighten right up.
The Following User Says Thank You to Thurman For This Useful Post:
jerseyguy1996 (12-24-2010)
Old 12-23-2010, 11:24 AM   #32
Just call me Andrew
Rewards Points: 1,020
So I guess those boxes work in both Albany, NY and Albany, GA!
Andrew
secutanudu is offline   Reply With Quote
Old 12-24-2010, 08:57 AM   #33
Those boxes look exactly like what I need. Thanks for posting that picture!
jerseyguy1996 is offline   Reply With Quote
Old 12-24-2010, 09:48 AM   #34
Scared Electrician
Saturday Cowboy's Avatar
I think you said that the wires were accessable in the attic? If so you could leave your box in the wall and put a jbox in the attic. pull one wire up leave one. and make all connections above.
Saturday Cowboy is offline   Reply With Quote
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 10:24 AM
Too many wires? fw2007 Electrical 10 06-28-2008 12:50 PM
