Counting Wires In A Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 10:10 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Originally Posted by jerseyguy1996 View Post
All of the plastic boxes that I found were too deep for the wall in that even when pressed all the way in they would still stick out about an inch.
Then you are going to have to cut out the wall and mount this.
http://www.grainger.com/Grainger/RAC...F32?Pid=search
Then add a one gang plaster ring for the switch.
The Following User Says Thank You to jbfan For This Useful Post:
jerseyguy1996 (12-22-2010)
Old 12-22-2010, 10:17 AM   #17
Is it something like this:
jerseyguy1996 is offline   Reply With Quote
Old 12-22-2010, 10:30 AM   #18
jbfan's Avatar
Rewards Points: 464
Yes, that is the plaster ring. You can get them in whatever depth you need to mount flush.
Old 12-22-2010, 12:40 PM   #19
Chewy - Lic. Electrician
ok so you are using 2 12-2 romex cables. so per 314.16(B) and as stated already. each of the conductors are 2.25 cu in2 so you have 2 hots and 2 neutrals and no matter how many grounds you have you only count one, and you dont count any wire that does not originate outside the box.(314.16(b)(1-5). So that said, 5 x 2.25 = 11.25 cu in2 so that covers the cu in2 for the wires. now add the device which counts for 2 of the wires in the calculations.
5 x 2.25 = 11.25 + 4.5 = 15.75 cu in2
you need to find a box that has a cu in2 meeting or exceeding that number, that meets your needs.
SGC622 is offline   Reply With Quote
The Following User Says Thank You to SGC622 For This Useful Post:
Old 12-22-2010, 12:57 PM   #20
So after I pull all of my wires through and install that plate on the box would I then cover everything except for the raised portion with drywall compound to finish it?
Old 12-22-2010, 01:01 PM   #21
the raised portion of the plaster ring should be flush with the wall so there should be only a smaller rectangle of the inner shape of the plaster ring that is not covered.
Old 12-22-2010, 01:07 PM   #22
Excellent. Looks like I have some more work to do. My wife will be thrilled to see me tearing open the wall again :-)
Old 12-22-2010, 01:21 PM   #23
jbfan's Avatar
Rewards Points: 464
Just look at all the practice you are getting!
Old 12-22-2010, 01:23 PM   #24
Well lucky for me there is only one room where the boxes were completely sealed into the finish surface. The other rooms still have gaping holes around the boxes so those will be easy to widen and replace.
Old 12-22-2010, 01:31 PM   #25
So just once more to be clear here. Once I attach the mud ring to the box and mud over it, I am basically sealing it into the wall. In other words there is no expectation that I should ever want to take the mud ring off again and all access to the wiring would all be through the opening in the mud ring. Is that correct or am I supposed to leave myself access to the screws that are holding the mud ring to the box?
Old 12-22-2010, 01:32 PM   #26
Experienced
Jackofall1's Avatar
You might want the inspection before you mud it in
Old 12-22-2010, 02:05 PM   #27
Good advice! Don't want to have to open it up for a third time
Old 12-22-2010, 02:06 PM   #28
Rewards Points: 256
And a follow up question to that would be, what good is it to sell a switch box that doesn't have enough room to accommodate the minimum number of wires required to operate a switch?
It would work for the minimum #of wires to operate a switch:
1 black
1 white(coded black)
1 ground
1 switch
michaelcherr is offline   Reply With Quote
Old 12-23-2010, 07:58 AM   #29
Rewards Points: 1,512
You can unscrew and remove one of the sides of the single gang metal box and buy a new (stamped or formed metal) side that bulges out a little to give more space inside. Usually you will be able to tilt the box so it fits back into the hole that held a straight sided box.
A 4 inch square box with a mud ring sealed into the wall with just the smaller opening (2-1/2 x 4 inch) and single switch or receptacle showing is acceptably accessible.
Old 12-23-2010, 10:09 AM   #30
Just call me Andrew
Rewards Points: 1,020
This is what Allan is talking about. It does fit in 1" deep plaster walls (I just installed one in my 1" thick walls). The total box depth is 2". You have to back the screws out of the wings a little to get them to fit around the thick walls, don't back them off too far - if the wings fall into the wall, time for a new box. These have 17 cubic inch capacity.
http://www.lowes.com/pd_239510-223-B...fo=1.0|Plastic
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
jerseyguy1996 (12-24-2010)
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 09:24 AM
Too many wires? fw2007 Electrical 10 06-28-2008 11:50 AM
