Countertop Receptacle Question. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-15-2013, 02:11 PM   #16
Rewards Points: 4,274
Check your local codes for safe distances between an outlet and water with regard to GFI. In our neck of the woods we can't go any closer than 36 inches unless the outlet is a GFI. If we can't get a GFI outlet in because of space problems then we must use a GFI breaker.
Bob Sanders is offline   Reply With Quote
Old 11-15-2013, 02:12 PM   #17
Originally Posted by Tonglebeak View Post
Just want to ask something. If I put one next to the right edge of the window then that would be less than 4ft. However that is behind the sink. I know I'm not required to put one behind the sink but if I do, will that count?
i believe it would count. in fact, if the distance from the back edge of the sink to the corner is greater than 18", then it is as if the sink isn't even there and you need to maintain the 2' distance all the way around.
just be sure that there isn't a point on the countertop that is more than 2' from a receptacle.
itsnotrequired is offline   Reply With Quote
Old 11-15-2013, 02:17 PM   #18
here in the states, ALL kitchen receptacles that serve the countertop surfaces must be GFCI, regardless of the distance from the sink.
Old 11-15-2013, 04:08 PM   #19
Rewards Points: 6,652
That is how it is in my neck of the woods, same as up at my Brother In-Law up in Lake County. It does not matter where the receptacle is at on the plane of the counter length, it must be GFCI protected.
Now add in the fact that they have tightened up the codes even more with the 2014 cycle, so time for everyone to get all of the electrical done, that you need to, before your area adopts the new code cycle.
Old 11-15-2013, 04:14 PM   #20
Master Electrician
Rewards Points: 3,964
Deleted
brric is online now   Reply With Quote
Old 11-15-2013, 04:50 PM   #21
The sink to the corner is 17" but if it will count then sweet I may go that route although the outlet spacing will look weird but whatever
Tonglebeak is offline   Reply With Quote
Old 11-16-2013, 05:49 AM   #22
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by bob sanders View Post
check your local codes for safe distances between an outlet and water with regard to gfi. In our neck of the woods we can't go any closer than 36 inches unless the outlet is a gfi. If we can't get a gfi outlet in because of space problems then we must use a gfi breaker.
6' ......
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-16-2013, 05:52 AM   #23
Rewards Points: 516
4' ............. OR 2' ( 24" ) from the edge of the countertop ... or edge of the sink
Old 11-16-2013, 05:59 AM   #24
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
edit....
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (11-16-2013)
Old 11-16-2013, 06:08 AM   #25
Rewards Points: 516
maybe a picture is worth a 1000 words ...LOL so here is 2000 ....
Old 11-16-2013, 02:32 PM   #26
Is that telling me that receptacles behind the sink do not count?
Old 11-16-2013, 02:51 PM   #27
Rewards Points: 516
correct ....
Old 11-18-2013, 08:22 AM   #28
sorry, should have worded as no point along the wall of the countertop surface be more than 2' from a receptacle, not 2' from anywhere on the countertop.
Old 11-18-2013, 08:28 AM   #29
correct ....
that is not my interpretation. if the sink rear edge is within the distances to the wall as indicated in the diagram, you don't need to include that portion of the wall as part of the wall space for spacing receptacles...but you are not prohibited from placing receptacles in the space. i would say if a receptacle is placed in the space, it would count toward the 2' maximum wall distance from a receptacle.
Old 11-18-2013, 12:07 PM   #30
Rewards Points: 516
Which would be CORN fusing ....
KISS theory always works best
2' from edge of the end of the counter and 4' between outlets .....
receptacle spacing question Tonglebeak Electrical 17 10-04-2013 04:04 PM
Question re wiring middle-of-run receptacle Rav Electrical 9 08-30-2013 08:49 AM
switch for middle of run receptacle jpau00 Electrical 4 02-05-2013 04:20 PM
Simple Countertop Question DrHicks Kitchen & Bath Remodeling 3 09-15-2011 04:14 PM
Receptacle wiring question cmaddy Electrical 7 07-20-2010 07:40 PM
