Countertop Receptacle Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2013, 12:17 AM   #1
countertop receptacle question.
I have a corner sink with 44 inches of countertop to the left. About nine inches in is the window which extends all the way to the sink. There's only 6inches between thewindow and tthe bbase cabinet. I'm having new countertops with A 4" backsplasg being installed so I won't be able to fit an outlet horizontallyunder ythe window without segmenting the back splash. What are some other things I can try to satisfy the outlet spacing requirement?
Tonglebeak is offline   Reply With Quote
Old 11-14-2013, 02:23 AM   #2
Electrician
Rewards Points: 150
Plugmold multi outlet strips by Legrand may be thin enough to fit in the 2 inch space that you have. They can be cord and plug connected or hard wired.
http://www.legrand.us/wiremold/at-ho...x#.UoSGa2t5mSM
Glennsparky is offline   Reply With Quote
Old 11-14-2013, 02:31 AM   #3
Electrician
Rewards Points: 150
Just found it. They're one and 9/32 inches wide.
http://www.legrand.us/~/media/produc.../Plugmold.ashx
Old 11-14-2013, 03:25 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
how big is the window ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-14-2013, 06:04 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They may infect be able to be cord and plug connected, but that would not meet code in this scenario….
Old 11-14-2013, 06:07 AM   #6
E2 Electrician
We always just install them in the back splash when this happens….
Old 11-14-2013, 06:08 AM   #7
E2 Electrician
Good question…. and a picture is worth a thousand words!
Old 11-14-2013, 06:21 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It sounds as if the window starts 9" from the far end of the counter top and is 36" wide. Thus butting up to the sink. You will need to figure out a way to get a recept within 2' of the sink's edge to satisfy the NEC. However, if you simply replaced the counter tops, I don't think you need to do anything.
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (11-16-2013)
Old 11-14-2013, 09:54 PM   #9
http://imageshack.com/a/img401/47/qdhp.jpg
the cooking mess.
Old 11-15-2013, 06:08 AM   #10
E2 Electrician
Originally Posted by Tonglebeak View Post
A receptacle to the left of the window should suffice the code requirement….
The Following User Says Thank You to stickboy1375 For This Useful Post:
Philly Master (11-18-2013)
Old 11-15-2013, 11:35 AM   #11
How so? The sink sits at a 45 degree angle. Isn't the line drawn from the front to the back of the sink at the same angle?
Old 11-15-2013, 11:54 AM   #12
bbo
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
Old 11-15-2013, 12:04 PM   #13
correct. for your application, the 'starting line' for the distance required starts more or less at the right edge of the window (draw a line parallel to the left side of the sink, back to the wall) and extends 2' to the left along the exterior wall. it will need to be below the window but as others have stated, it can be in the backsplash. what are you using for backspash material?
itsnotrequired is offline   Reply With Quote
Old 11-15-2013, 01:30 PM   #14
Grqnite
Old 11-15-2013, 02:07 PM   #15
Just want to ask something. If I put one next to the right edge of the window then that would be less than 4ft. However that is behind the sink. I know I'm not required to put one behind the sink but if I do, will that count?
receptacle spacing question Tonglebeak Electrical 17 10-04-2013 04:04 PM
Question re wiring middle-of-run receptacle Rav Electrical 9 08-30-2013 08:49 AM
switch for middle of run receptacle jpau00 Electrical 4 02-05-2013 04:20 PM
Simple Countertop Question DrHicks Kitchen & Bath Remodeling 3 09-15-2011 04:14 PM
Receptacle wiring question cmaddy Electrical 7 07-20-2010 07:40 PM
