Coundit Size - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 06:16 PM   #1
Coundit size
I'm running 4 #6 wires for a sub panel under ground about 90' the panel will be 60 amps i want to use pvc but need to know the right size to get to hold all this. There will be 2 90s and a pull box on each end.
AJPOLCARI is offline   Reply With Quote
Old 10-02-2012, 06:43 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
1" PVC would work.
Just so you know, you can run a #10 ground for this. It does not need to be #6.
Also, why the pull boxes?
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 01:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 09:49 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
