Cost of replacing old knob ant tube wiring in house
Hello and welcome aboard!!
I'm not an electrician, but I can tell you alot will have to do with where you're at. Rates vary alot by region and even between rural & urban areas within any given state. Best bet is to make a few phone calls to local guys to get some ballpark numbers.
If you have the knowledge, skills & tools to run the wire yourself and do alot of the labor you maybe able to save yourself some $$. I have a guy that works for me that's a great electrician, but unlicensed, he does most of our work and I sub a licensed local guy, he checks the work, basically inspects everything & pulls permits. Keep in mind this is a very rural area of Mo and our rules are very lax compared to many areas of the country, and you may not be able to get by with such an arrangement.
First thing to do is to check with local building inspector's office and see what is required locally. One thing I've learned is it's best to check in first and make sure you're not creating problems for yourself down the road.
All you need is ignorance and confidence and success is assured. - Mark Twain
