Cost For Plugs - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 06:42 PM   #1
cost for plugs
how much should it cost to add 5 plugs, 3 fans and 2 porch lights to a enclosed porch? wiring and installing the fixtures. also a new run to the panel.
lilipads1 is offline   Reply With Quote
Old 04-05-2011, 09:22 PM   #2
Mad Scientist
Since I don't know the layout, the existing wiring, the structure, the existing panel, or the total distance, I'm going to say somewhere between $0 and $20,000.01.
McSteve is offline   Reply With Quote
Old 04-05-2011, 09:34 PM   #3
" Euro " electrician
frenchelectrican's Avatar
There is too many variations to determed what the cost to do it.
If you going to do it yourself it may cost just under couple hundreds Euros.
But to hire a electrician to come out and deal with it the best answer is have 3 diffrent bids to see what the cost plus with enclosed porch you will denfiely need a GFCI receptale anyway.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
lilipads1 (04-05-2011)
Old 04-05-2011, 09:54 PM   #4
they were asking me $1500
I just wanted to make sure it was a fair quote.
Old 04-05-2011, 09:57 PM   #5
What state you are in ? once I know which state then I can able see if that is fair or not and what type of structure like brick wall etc etc I know with brick wall they useally cost more due it take more time to drill thru.
Merci,.
Marc
Old 04-05-2011, 09:58 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
get an estimate from another company and compare. Depending on the amount of work involved, that could be way over priced or under priced. It just isn't possible to give you any sort of accurate price over the internet.
The Following User Says Thank You to nap For This Useful Post:
Old 04-05-2011, 10:01 PM   #7
I'm in Florida
and it's a stud addition not block
Old 04-05-2011, 10:03 PM   #8
Did you check other two electrical contractor to make sure the price in fair range ??
Merci,
Marc
Old 04-05-2011, 10:06 PM   #9
I called two today but they never got back with me......I will try again tomorrow
Old 04-05-2011, 10:08 PM   #10
Ok once the other two call you back with the price then you will know where ya stand with pricewise.
Merci,
Marc
Old 04-05-2011, 10:10 PM   #11
Thanks for the info.
Old 04-06-2011, 12:26 PM   #12
Rewards Points: 3,130
Does the quote you got include the fans and light fixtures? If not, it seems high to me. I got the entire 1600 square foot house I'm building wired (roughed in) for barely twice that much.
Furnace Installation Cost philstewart HVAC 32 04-13-2014 02:44 PM
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 07:04 AM
Can we get a cost estimate subforum going Will1987 Site Help and Suggestions 8 04-02-2009 08:57 AM
Hot Water Heater Installation Cost philstewart Plumbing 6 10-29-2008 06:05 PM
