Cost Of New Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 01:52 PM   #1
Question
Cost of new electric
Hello!
I have found a really cheap Fixer Upper, which I am very interested in. It has some fire damage (I can fix most of it myself: Walls. Flooring, Doors, Paint, etc).
Now the problem is, that the electric of the house also was damaged during the fire (melted cables, outlets, I also think the fuse box is defect.)
I am not able to install new electric myself, so I am curious how much it would approximately cost to get entire new electric for the house (it is a TINY, older 2 BR bungalow)
I am going to get an estimate from an electrician, but I would like to know abooout how much to expect before I do that! I have no idea! $500? $1000? $5000?
Thanks already for the answers and help!
Shane
MrOatmeal is offline   Reply With Quote
Old 01-05-2011, 02:09 PM   #2
Where are you located ?
Old 01-05-2011, 02:10 PM   #3
Memphis, TN
Old 01-05-2011, 02:14 PM   #4
Rewards Points: 256
Consider having an electrician do the panel, then do all the branch circuit wiring yourself.
Are you talking replace every piece of wiring in the house, if so I'd say 5k if I had to pick one of those three numbers.
michaelcherr is offline   Reply With Quote
Old 01-05-2011, 02:19 PM   #5
Price will vary by your exact location, number of circuits
How much needs to be replaced, outlets, breakers, panel ?
And how much access there is to run wire, crawlspace, basement, slab
Since its being renovated you will most likely have to meet today's code
Your best bet is to get several local estimates
Anything else here is a very rough guesstimate
Old 01-05-2011, 02:33 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,970
You sure can do it yourself! If you can learn to do all those other trades well enough to fix up the place, then you can learn to rewire a tiny old house. You can probably do it for under $2000 in materials. Probably WAY under that, but it depends on too many specifics to say without more information.
Get a good DIY wiring book, and a copy of the current electrical code in your jurisdiction. I'd recommend the NEC handbook instead of just the code book, since the added explanation and diagrams are very helpful.
If you are thoroughly gutting the interior, you'll want to do all the wiring while the drywall is removed of course. If your inspector is cooperative, you can replace the main panel first to get power turned on temporarily so you can run lights and tools while you finish the job.
mpoulton is offline   Reply With Quote
Old 01-05-2011, 03:16 PM   #7
What is the square footage of the house?
How many floors are finished?
Attic? Basement?
That will help with an estimate. But I am sure you are looking at $10,000 at least.
Most of this work is time consuming, if you decide to do it yourself you will save a lot of money.
General is offline   Reply With Quote
Converting duplex to single family--what to do with electric services? zamoti Electrical 32 01-29-2009 03:16 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
Very high electric bill. 68MHJCs Electrical 58 08-08-2008 08:48 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 10:07 PM
electric oil boiler? for hot water? jamesdart Plumbing 2 01-13-2008 08:06 PM
