Cost Of Electricity?? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 05:58 PM   #1
What can I find here?
Winchester's Avatar
Rewards Points: 150
Cost of Electricity??
Since Watts = Voltage x Amperage
.....am I paying more because I have an average incoming voltage of 124 volts instead of 120 volts??
Winchester is offline   Reply With Quote
Old 02-12-2009, 06:17 PM   #2
Electrician
ctsmiths's Avatar
Rewards Points: 150
you pay based what you use not what have available
ctsmiths is offline   Reply With Quote
Old 02-12-2009, 06:20 PM   #3
WFO
Short version....Not really. For example, the element of your heater is hotter, so it runs less, so work is about the same. Watts are watts. Maybe on your incandescent lighting.
Longer version....there's not much you can do about it, since the POCO can't do much about it either (depending where you are on the line). POCO's use voltage regulators that keep the voltage within a certain range, and are set up to not overvoltage the first guy without undervoltaging the last guy.
For example, we try to maintain a delivery voltage between 126 and 118 volts. The customer closest to the regulator gets 126, the one at the end of the line gets 118. The one in the middle gets the closest to the nominal of 120. There's no such thing as maintaining a constant 120 volts unless you are willing to cough up the money for your own equipment (which wouldn't be worth it unless you have a voltage sensitive manufacturing system (i.e., robotics or silicon production) that requires it.
WFO is offline   Reply With Quote
Old 02-12-2009, 06:50 PM   #4
Electrician
ctsmiths's Avatar
Rewards Points: 150
If you have a fixture with a rated watt load it will use the same load in watts at 120 and 124 or 114 volts. the amps will change to accomodate the load but 60w is 60w any way you slice it.
Old 02-12-2009, 07:45 PM   #5
Your 120v incandescents will last 100[(120/124)^16] = ~60% of their rated life.
"For a supply voltage V,
Light output is approximately proportional to V^3.4
Power consumption is approximately proportional to V^1.6
Lifetime is approximately proportional to V^−16
Color temperature is approximately proportional to V^0.42"
Old 02-12-2009, 09:21 PM   #6
Electrician
ctsmiths's Avatar
Rewards Points: 150
I love it when you talk like that.
Old 02-13-2009, 11:42 AM   #7
You might be in the minority. . .
Old 02-16-2009, 12:05 AM   #8
I don't see it. V=IR. The volts and amps are directly correlated since the resistance does not vary. The more amps, the more watts.
For a 100 watt bulb the resistance will be 144 Ohms and at 120 Volts the current will be .8333 amps.
120=.8333*144
If you bump it to 124 volts
124/144=.86
Using power=R*I^2
144*.86^2=107 Watts
On a lighter note, 100 Amps of survice will be able to power more at 124 Volts than 120 volts.
joey b is offline   Reply With Quote
Old 02-16-2009, 11:10 AM   #9
120=.8333*144
124/144=.86
Using power=R*I^2
144*.86^2=107 Watts
V = IR but the R for an incandescent lamp is affected by I. "Cold" R is 10x to 15x less than "hot" R.
This equation is hidden in the relationships that Wiki posts for incandescents.
"Power consumption is approximately proportional to V^1.6"
Old 02-16-2009, 03:23 PM   #10
fact remains, that the higher the voltage, the higher the power usage.
(124/120)^1.6~ 105%.
You also have to consider that many things do not follow the same properties as incadescent light bulbs. Copper wiring for example has a higher resistance as it heats up.
Is the OP paying more? Yes. Is there much can be done about it? No.
Old 02-16-2009, 04:10 PM   #11
40A buck-boost xformer, $350.
Payback period=???
Old 02-16-2009, 04:16 PM   #12
Electrician
ctsmiths's Avatar
Rewards Points: 150
So in the winter you could say that for the northernhalf of the country,energy consumption should fall because the copper is colder= less resistance
Old 02-16-2009, 04:46 PM   #13
yeah, because the amount of heat put off has a huge impact on the amount of petroleum used to heat homes.
Old 02-16-2009, 04:55 PM   #14
DIYer
The efficiency does increase by a small amount because of it. I'm sure if a power company cared to measure they could easily see the lowered wire loss.
Gigs is offline   Reply With Quote
Old 02-16-2009, 05:05 PM   #15
Knowing the tempco of copper you can pull this info out of table 310-16 in the NEC. The R for copper increases by 1.3x for a 100℃ temp rise above +20℃. It's a messy calc. and it's approximate.
Furnace Installation Cost philstewart HVAC 32 04-13-2014 01:44 PM
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 10:20 AM
new home foundation cost wdsfr1968 Building & Construction 8 03-03-2010 10:59 AM
Hot Water Heater Installation Cost philstewart Plumbing 6 10-29-2008 05:05 PM
