Cosmetic Wall Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 05:46 PM   #1
cosmetic wall switch problem
Using old work boxes I have mounted timers to control bathroom fans.
The plate for each timer sticks out from the drywall surface 2/32" or 3/32".
Is there a gasket that is made to fill this gap?
Anyone else have this problem?
Caulking is not my first choice to solve this.
Old 03-18-2009, 06:12 PM   #2
The plastic old work boxes? Yeah, most old work boxes make the device flush to the wall. And some plates are very small. I like the P&S unbreakable plates, they should be enough to cover the gap you are talking about.
I don't know of any gasket, but there might be.
Picture?
rgsgww is offline   Reply With Quote
Old 03-18-2009, 07:03 PM   #3
No picture but the switch plates are parallel to the wall surface but a small distance away from the wall surface.
Old 03-18-2009, 07:23 PM   #4
I know exactly what you are dealing with. A different cover plate may help. The nylon plates we use seem to have a little more depth than the oldschool ones.
If that wont do it, try to tighten the box more so it sucks into the drywall a bit.You might even have to use your razor knife and take out a tiny bit of the drywall paper.
Be careful.
220/221 is offline   Reply With Quote
Old 03-18-2009, 10:54 PM   #5
Be careful.
Yes, I think I'll abrade or cut away some of the drywall surface so the box sits farther into the wall.
4-way switch problem judyconte Electrical 3 03-18-2009 08:43 AM
Wall switch inop Usafric Electrical 3 09-08-2008 06:44 AM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 06:51 AM
Can lights, wall switch and BX (in Chicago) alvanos Electrical 7 03-02-2008 09:48 AM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
