-   -   Is this a cose violation (http://www.diychatroom.com/f18/cose-violation-14154/)
Century 12-06-2007 03:40 PM
Is this a code violation
Hello,
I have an attached garage on my house. All the plugs and lights in the garage are tied into 1 15 amp breaker. The garage door opener is plugged into the ceiling. I have had the breaker trip and the garage door looses power as well. Is this a violation or just done wrong? The company that wired my new house is not interested in helping out. I am located in Louisville, KY
Thanks in advance for your help,
Ben
Ron6519 12-06-2007 03:55 PM
It may or may not be a code violation. It could be a bad opener, a bad breaker, too much load on the circuit or an intermittant short. Do some detective work. Find out what's on the circuit with the opener. Trace all the switches, outlets, lights and what's plugged into them. Somewhere in the circuit is the answer.
Ron
Century 12-06-2007 04:05 PM
Hi ron,
All the plugs, light and switches are tied in with the plug for the door opener. When the breaker trips all lights and plugs go out. The garage door is not what is tripping the breaker. The breaker will trip without the door being used. I was told that the garage door was to be on a separate breaker in case the current breaker tripped I would still be able to open the garage.
Thanks,
Ben
kgphoto 12-06-2007 05:31 PM
You have troubleshooting issues to deal with there. It is not feasible to trouble shoot over the internet. Find an electrician there to solve the problem and then send the bill to the builder. Finally take them to small claims once they ignore the bill. Be safe.
Ron6519 12-06-2007 07:04 PM
I don't know of a code that specifies a garage door opener gets a seperate breaker. You mention that the electricians will have nothing to do with it. Is the house under warranty? How long was the electricians work guarranteed for?
Short term, it doesn't matter. Short term, the question is, what is the problem ? As a point of interest, the garage door has a release cord, that when pulled, will release the door from the track so it can be opened the old fashioned way. By lifting it up.
As kpphoto said, this is troubleshooting. If you don't have any experience with this, you need to call an electrician to fix the problem. You can deal with the builder/electrician after it's fixed.
Ron
Stubbie 12-06-2007 10:33 PM
Hello Century
Who said we can't troubleshoot over the internet??.......:mad:
If this is a new home and all the lights and receptacles in the garage are on the same breaker then there has to be a gfci involved somewhere. Is the breaker a gfci breaker? Or is one of the receptacles a gfci receptacle?
Century 12-06-2007 11:05 PM
Thanks Stubbie. It is a new home. I am not sure about the type of breaker or receptacles. But I will be finding out. I have a State inspector calling me tomorrow.
Ben
Stubbie 12-06-2007 11:42 PM
Century
This is a gfci breaker...
http://images.orgill.com/200x200/6122568.jpg
This is a gfci receptacle... they don't all have the red button.
http://www.jigyo.com/FleaMarket/Grap...utlet15amp.jpg
Century 12-06-2007 11:57 PM
I ment to say no on the receptacles. I checked the breaker and no that is not the kind it is. So no on both.
Thanks Again
Stubbie 12-07-2007 12:08 AM
OK there is probably a gfci receptacle in the house that protects the garage receptacles this is a code requirement for all garage receptacles. It could be one in the basement or elsewhere. It would not be required to protect the garage door opener receptacle if it is in the ceiling.
What things are plugged in and operating when the breaker trips include the lights. You said the opener motor doesn't need to be running. So we need to make sure what is operating doesn't exceed 15 amps. You need to find everthing that quits working with the breaker off because we need to know the load on this branch circuit.
Speedy Petey 12-07-2007 05:41 AM
Stibbie's thinking is right on.
Also, how new is new? Most every area has at least a one year warranty mandated by the state or local authority.
One 15A circuit to a whole garage, lighting AND receptacles, is a joke. The installer was a hack.
LawnGuyLandSparky 12-07-2007 05:43 AM
How new is the house? You have a garage receptacle and an opener receptacle, what other receptacles are on this circuit?
Century 12-07-2007 11:24 AM
The House is brand new. I am the first person to live here. There are 4 receptacles, 2 lights inside, with 2 outside lights on the garage. The opener is plugged into one of the receptacles on the ceiling.
The electrical contractor has been very rude when I have spoken to them. Today I even have breakers tripping in the bedroom. I am thinking of having the whole house inspected.
Thanks,
Ben
J. V. 12-07-2007 11:47 AM
Hack job. Perfect description on the install. 15 amp circuit for the WHOLE garage. Dispicable.
Contact the builder right away since this is a brand new house.
The dedicated circuit for the opener while not required, is sure darn good thinking.
In a standard two car garage, (2) twenty amp circuits sounds about right, from a design standpoint.
I would have concerns regarding the whole job.
Century 12-07-2007 11:51 AM
I am thinking of paying to have it all inspected.
Thanks,
Ben
