Old 12-12-2011, 11:57 AM   #1
buckybadger's Avatar
Correcting Open Ground - Switched Disposal/Dishwasher Receptacle - Picture Included
I was using my outlet tester around the house and came across an open ground in the outlet under the kitchen sink for the dishwasher/disposal. The top half of the receptacle is controlled by the switch for the disposal.
The only missing link in the ground path is a direct splice between the switch and receptacle although the switch and receptacle are grounded to the two respective boxes, which are connected by metal flex conduit. I know on paper the switch and receptacle should be directly connected, but shouldn't the way this is set up be providing a grounding path? Since my tester reads open ground my inclination is to just run a grounding wire between the two wire nuts (picture).
Here's a picture to make things clearer.
www.patrickdaley.com/sink.png
buckybadger is offline   Reply With Quote
Old 12-12-2011, 12:07 PM   #2
retired elect/hvac/plumb
plummen's Avatar
if the boxes are not mechanically grounded through conduit all the way back to the panel,or if the piece of romex sleeved through the flex is not bonded to the metal boxes with a ground screw you will have no ground through the boxes.
plummen is offline   Reply With Quote
Old 12-12-2011, 12:10 PM   #3
In both of the metal boxes the ground from the romex is connected to a ground screw.
Old 12-12-2011, 12:18 PM   #4
plummen's Avatar
is it bonded in the service panel?
Old 12-12-2011, 12:20 PM   #5
I can't say with absolute certainty, but there is a metal j-box in the ceiling of the basement just upstream from this with a receptacle that does test as being grounded.
Old 12-12-2011, 12:26 PM   #6
plummen's Avatar
go from the hot side of plug under sink to the ground wire with your meter,that will tell you if its grounded back to panel or not.
Old 12-12-2011, 01:08 PM   #7
I'll check that when I get home.
Could my tester be showing "open ground" because the switch and receptacle don't have their grounds directly spliced together?
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
Open Ground Remedy? gksmith6 Electrical 5 01-04-2008 07:32 PM
Open Ground? Cornfused JRoot Electrical 15 10-29-2007 02:20 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
