Correct Wire Size? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 11:02 AM   #1
Correct wire size?
Having a senior moment I purchased the wrong size wire for a electric floor heating wire. I have purchased #10 2 wground
I am using a WarmWire DFT 2215 which is a 240 volt unit:
Wire length is 876 ft
2576 w
10.7 a
21.6 ohms
curcuit length is 50 ft.
I am using a 20amp breaker.
I have already run the wire ... so there is no returning it... and I really do not want to pull it out.
My question: can I use the #10 in place of the #12 with the 20 amp breaker without doing any potential damage to the heater. I am to embarassed to ask my electrical friend. Please help.
fatczech is offline   Reply With Quote
Old 12-18-2011, 11:13 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
The only problem will be connecting the wires, otherwise no issue.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
fatczech (12-18-2011)
Old 12-18-2011, 11:17 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Yes...upsizing the wire is no problem. You may want to tag it in the panel for future reference as to what it's connected to.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Old 12-18-2011, 07:11 PM   #4
Hey JB Fan
Thanks much for your help and assistance. Where do you forsee a problem with connecting the wires?
Old 12-18-2011, 07:14 PM   #5
Rewards Points: 582
2576 w
10.7 a
21.6 ohms
shoulden't be a problem
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 12-18-2011, 07:35 PM   #6
I=E/R
a7ecorsair's Avatar
It is just that #10 is harder to work with than #12
3
a7ecorsair is offline   Reply With Quote
Old 12-18-2011, 08:15 PM   #7
#12 is not easy
I salvaged some old white romex #12... geezh! The sheating and the wire was nearly impossible to work with.
BTW.. thanks for the help
Ground Wire Size?? Giles Electrical 1 02-07-2011 08:09 PM
What size wire to use running underground ms66cadillac Electrical 21 01-13-2011 11:14 AM
What size wire do I need? walnut777 Electrical 1 12-13-2010 06:41 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
