Correct Way To Wire Electrical Relay ? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 11:06 AM   #1
Rewards Points: 85
Correct way to wire electrical relay ?
Hi,
I want to install a low voltage thermostat to control a fan-forced heater (5000W). I will need to install a relay and I wanted to make sure my wiring is correct.
I will go with the following relay:
Product page: http://www.aubetech.com/products/pro...=42&noLangue=2
Install manual: http://www.aubetech.com/manuel/2/RC840T.pdf
Here's my wiring diagram:
westbank is offline   Reply With Quote
Old 10-25-2012, 11:18 AM   #2
joed's Avatar
Rewards Points: 13,728
Based on the manual link you have it wrong. You need to swap the blue and red wires coming out of the stat. The blue and black need to go to the line coming in.
Old 10-25-2012, 12:27 PM   #3
Rewards Points: 85
Like this:
Old 10-25-2012, 12:30 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,990
Your wiring will cause a dead short across the incoming power when the thermostat turns on. Not good - will probably kill the relay. Switch blue and red, as joed says.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-25-2012, 12:46 PM   #5
biggles's Avatar
connect one line feed thru the N.O. contacts on that relay so the stat closes that N.O. to cycle the heater
Old 10-25-2012, 02:12 PM   #6
Rewards Points: 85
Thanks for the advice. So my second wiring diagram is correct ?
Old 10-25-2012, 02:55 PM   #7
Looks like it, yes.
Old 10-25-2012, 06:21 PM   #8
joed's Avatar
Yes second diagram looks correct.
Can Electrical Wire go on the I-Beam thebrandnewguy Electrical 8 08-12-2011 10:16 PM
Low voltage wire & electrical wire (NM) dyang Electrical 3 05-04-2010 10:02 PM
Running electrical wire into 98 Buick Lasabre Red Squirrel Automotive Repairs 5 04-22-2010 09:08 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
